 Post subject: Fail Processing Track
PostPosted: Fri Apr 04, 2014 11:45 pm
Here is track that bothers me last few days.
http://www12.zippyshare.com/v/89475645/file.html
Fail point ~00:22sec.
Does anyone have idea how to make this track to not fail.
I ofc checked all existing presets, and evry one of them fails, and also tried everything i can in ST.
So maybe someone at least have an idea how/what to do. I actually have many similar examples and most of them are r'n'b.
I know why this track fails, but thing is that i can't fully fix it.
Also checked orban8200 wich totaly fails. Would be also good if someone can process (check) this track on other processor.
PostPosted: Sat Apr 05, 2014 12:24 am
Why does the prosessor fail? To much agc? The lows are massive, how do you try to prosess it?
PostPosted: Sat Apr 05, 2014 1:05 am
Try yourself and you'll see (hear) - very easy.
PostPosted: Sat Apr 05, 2014 10:36 pm
I've tried a few of my own settings w/out massive fails…I'll try some more see if I can figure out where the fail comes.
PostPosted: Sun Apr 06, 2014 12:28 am
Very easy actually..
If there is enough AGC range (as it should be) it will go up at first 22 sec of track. After that it will go down making track to overall sound less loud. Thing is that there is no enough range in MB to recover that, or less possible that AGC does not work good.
Strange is also that i tried multiband with full inf:1 ratios and even with full Feed-Forwad mode, And it still happens.
PostPosted: Sun Apr 06, 2014 1:23 am
Just realized that Ratio settings in ST works wrong.
PostPosted: Mon Apr 07, 2014 2:41 pm
Is there a fail here at :22? I can't say that I hear any overall loudness change at that point. This is recorded from an Inovonics 530 FM Modulation Monitor tuned to a 1 watt Broadcast Warehouse exciter using my Open WIDE preset.
http://downloads.bobandtanya.com/Beyonce.mp3
PostPosted: Mon Apr 07, 2014 5:06 pm
Did you used AGC at all? And is it super slow?
PostPosted: Mon Apr 07, 2014 6:52 pm
Yes...and it is quite slow. If I suddenly reduce the audio input by 20db from the console, it takes 15-20 seconds for the AGC to fully recover. I posted the preset in the preset forum if you'd like to look under the hood.
PostPosted: Mon Apr 07, 2014 10:54 pm
well I assumed it was it ;)
