PostPosted: Mon Aug 05, 2013 10:52 pm
How about a way to display every setting in every preset (including self created ones) on a spreadsheet?
 Post subject: Re: Spreadsheet
PostPosted: Tue Aug 06, 2013 2:51 am
If you want to compare 2 presets, WinMerge works very well... Save both .sts files and open them in WinMerge, and you'll see exactly what's different between the two.
PostPosted: Tue Aug 06, 2013 4:35 am
Notepad++ with "Compare" plugin.
PostPosted: Tue Aug 06, 2013 1:43 pm
Had forgotten about my old favorite WinMerge (have never used Notepad++)...good to know .sts files will work with it. Thanks guys!
