 Post subject: Icon - 9 Band Processor
PostPosted: Thu Jun 06, 2013 6:49 am
A new 9-band preset, power and clean, enjoy! :lol:
GAP_Icon_v0.1.zip [9.99 KiB]
Downloaded 574 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Tue Jul 09, 2013 6:32 am
Update preset ST v7.24 beta 28 ;)
- Add more dynamic and power bass
- Overall adjustments.
- 100 % clean sound!
GAP_Icon_v0.2.zip [10.02 KiB]
Downloaded 452 times
by GAP
PostPosted: Wed Jul 10, 2013 3:48 am
Kick is making holes in sound - for example > Alanis Morissette - Wake Up
PostPosted: Wed Jul 10, 2013 2:47 pm
Last night reviewing the preset I've heard in some tracks that have a problem ... (I was experimenting, use more bass transients, but I think I spent ... this has a very tight limit.)
I was fixing this, but I need some more test ...
Soon will update, thanks Bojcha. ;)
by GAP
PostPosted: Wed Jul 10, 2013 3:59 pm
You may want to try to use "burst".. might be better quality then using limiters.
PostPosted: Thu Jul 11, 2013 3:24 pm
It is an option, but when I have used in my notebook, used too cpu and could not use them without interrupting the sound.
I'll try again, I hope to me a while tonight. ;)
by GAP
PostPosted: Fri Jul 12, 2013 6:52 am
I think the problem is now fixed, give me your opinion. ;)
GAP_Icon_v0.3.zip [10.16 KiB]
Downloaded 416 times
by GAP
PostPosted: Wed Jul 17, 2013 1:23 am
Has anyone tried the preset, and if I am able to verify solved the problem mentioned by Bojcha?
I few days of vacation (winter over here), and I have no devices to test ... :lol:
by GAP
PostPosted: Sat Jul 27, 2013 6:29 am
Some spectral corrections ... surely notice. ;)
GAP_Icon_v0.4.zip [11.09 KiB]
Downloaded 427 times
by GAP
PostPosted: Mon Jul 29, 2013 4:54 am
I leave the final version, unless someone thinks that something is wrong.
Sound a little open and controlled simultaneously.
Hope you like it. :)
GAP_Icon_v0.5.zip [11.09 KiB]
Downloaded 531 times
by GAP
