 Post subject: Stereo Tool 7.23 BETA
PostPosted: Tue May 28, 2013 12:10 pm
BETA 723-001
Stand alone: http://www.stereotool.com/download/ster ... 23-001.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 23-001.exe
VST: http://www.stereotool.com/download/vst_ ... 23-001.dll
Changes:
- Improved Stokkemask clipper; far less effect on audio (from 2 dB loss in highs to 0.7 dB)
- Added RF spectrum analyzer. Warning: Uses a lot of CPU power.
- Added option to remove demodulated L/R spikes above 100% (level is configurable).
- BS412 in composite clipper mode improved (there were some issues with the level calculations).
The RF spectrum analyzer shows small Stokkemask overshoots, I think that's only caused by the used window shape that's not 100% identical to the ones used in spectrum analyzers. Also the Stokkemask analysis requires some smoothing of the output which causes a reduced peak level, which is not implemented in the RF display in Stereo Tool. Would be nice if someone with a hardware spectrum analyzer could run a (long) test to see if there are really no Stokkemask overshoots left.
Todo:
- smart_reflect_counter==4 DONE
- aggressiveness calculation? DONE
PostPosted: Tue May 28, 2013 5:44 pm
BETA 723-002 (NEARLY release candidate, see TODO below)
Stand alone: http://www.stereotool.com/download/ster ... 23-002.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 23-002.exe
VST: http://www.stereotool.com/download/vst_ ... 23-002.dll
Changes:
- Stokkemask clipper now works well at all Strictness settings
Old changes:
Todo:
- Disable 'Clip at' when the Demod clipping is off. DONE
PostPosted: Wed May 29, 2013 9:53 am
BETA 723-003 (release candidate)
Only change vs 002 is that the 'Clip at' slider is disabled in the display if 'Clip demod peaks' is disabled.
And I replaced Brian's Cobalt preset by the latest version (separate ones for Web and Generic).
Stand alone: http://www.stereotool.com/download/ster ... 23-003.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 23-003.exe
VST: http://www.stereotool.com/download/vst_ ... 23-003.dll
Old Changes:
PostPosted: Wed May 29, 2013 10:44 am
Thanks... Looks OK.
Since you synchronized them, I'll start trying to work on something using the new stuff. Probably going to have to be at reduced quality / reduced bands, as I'm starting to figure I'm going to be on this old computer for a good long while still. Haven't heard anything, and while not hearing anything is not necessarily "bad news", it does mean things will remain the same.
Request for sometime soon:
- Separate spike protection for band 1 and 2 (and 3, if keeping 3) in AGC.
You also know my opinion about updating the compiler / libraries...
PostPosted: Wed May 29, 2013 1:55 pm
I have now also fixed the bug that caused some warning messages to keep occurring after a restart.
PostPosted: Wed May 29, 2013 11:39 pm
BETA 723-004 (release candidate)
Fixed: Warnings kept being shown after restarts.
Stand alone: http://www.stereotool.com/download/ster ... 23-004.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 23-004.exe
VST: http://www.stereotool.com/download/vst_ ... 23-004.dll
Old Changes:
PostPosted: Thu May 30, 2013 12:15 am
Link for standalone version not working.
PostPosted: Thu May 30, 2013 12:27 am
Noticed that there is 2 places where is stokke section.
PostPosted: Thu May 30, 2013 10:31 am
Fixed.
PostPosted: Thu May 30, 2013 10:33 am
This has 2 reasons:
1 - It's part of the Advanced Clipper (cannot run without it)
2 - It has a big effect on the audio (although it's less now in this version).
