PostPosted: Sat Apr 27, 2013 7:58 pm
Well,
Due to some artefacts i found with my 9 band version, i tried to make a nice preset, but now a 6 band version.
Please let me know what you think.
Composite clipper is enabled, phase shaping enabled, ASIO, Stereo enhancement quite a bit :geek:
:!: Thanks you all for reply....StereoTool makes this fine sound because all of you !
EDIT:
:arrow: Spideys Web is a easy listening preset for webstreams
:arrow: The Sixth sense could be seen as a 6 band hitradio preset.
Web preset has been made on request, and is made as SAMCAST DSP plugin.
So please leave comments if you like.
If you guys would like to listen to the stream, please tune in to: http://yp.shoutcast.com/sbin/tunein-sta ... s?id=46475
Spideys Web by Jeroen Platenkamp.sts [43.98 KiB]
Downloaded 806 times
6th Sense II by Jeroen Platenkamp.sts [50.41 KiB]
Downloaded 891 times
PostPosted: Sun Apr 28, 2013 2:57 pm
Jeroen.
Sounds nice,nice deep low and crispy high. :)
But can you make from this preset a " web " version
For streaming audio?
Becouse personal i dont use FM..
Goed bezig Jeroen :)
Garbage in is Garbage out !
PostPosted: Sun Apr 28, 2013 3:57 pm
For some reason when I try your King preset, or this preset, with clipping on, the FM output goes constant red no matter what...some audible distortion noted.
PostPosted: Sun Apr 28, 2013 4:31 pm
Because for some reason he does not enables "Hard Limit"
PostPosted: Sun Apr 28, 2013 7:43 pm
Well, on the DEVA not overshoots are detected, so why enable hard limit ?
I also experience red meters, but i don't hear any distortion.
Don't know exactly what the red output meter mean, maybe Hans can clear this :?:
For now i enabled HARD LIMIT, witch also gives me red meters (not constant)
PostPosted: Mon Apr 29, 2013 3:56 am
I'm playing around with it right now. I like it!
PostPosted: Fri May 03, 2013 4:48 pm
Red meters = overshoots!
Now they may be really small (just 0.001% or so), but without Hard Limit you might get bigger overshoots in some rare circumstances.
Red blinking with Hard Limit should be fixed in the next version (will probably upload it tonight).
PostPosted: Tue May 07, 2013 7:42 am
@Parelduiker
I have adjusted the preset for the release candidate version, i will upload it asap and then i will concentrate on a nice and smooth web version (like radio 10 gold webstream)
PostPosted: Tue May 07, 2013 4:19 pm
Jeroen.
Well here it is.
Personally i made a nice and easy preset called Spidey's Web, personally i think WEBstreaming is another ballgame !
Should be very nice and easy listening, since there is no loudness competition.
It a completely different preset, but very nice to listen to for a long time, tried and tested on dsp plugin for SAMCAST 192Khz stream.
WebSter by Jeroen Platenkamp.sts [49.8 KiB]
Downloaded 757 times
PostPosted: Tue May 07, 2013 4:30 pm
This stereo boost settings makes confusion in my head.
