PostPosted: Wed Apr 03, 2013 4:03 am
Anyone got a favorite case they use for ST.Looking for something small with MB/CPU combo that will take the Marian Trace Alpha card .Looks like a mini-tower case may be a way to go.Looking for something to take on the road and demo ST.With the new ST features coming,quad core cpu will probably work the best.
I have a Dell I5 but it's too nice to lug around in a truck,it's my home toy..
PostPosted: Thu Apr 04, 2013 9:36 pm
Wouldn't a laptop, or better - a *fast* netbook with an USB audio card work for you? I *think* there are nice 192khz capable sound cards out there that can work via the USB.
PostPosted: Fri Apr 05, 2013 7:49 pm
If used for FM broadcast, the Marian sound card is a must. That rules out all laptops/notebooks that I'm aware of.
PostPosted: Fri Apr 05, 2013 9:19 pm
Juli@ is not so bad also!
PostPosted: Fri Apr 05, 2013 10:56 pm
Are the ESI Juli cards DC straight?
This looks like an easier to obtain card in the USA! Getting our Marian was.....erm....
difficult.
PostPosted: Sat Apr 06, 2013 2:47 am
No it's not.. but ralitvely easy to set tilt (now possible in ST)
I have one Marian trace Alpha at one transmitter, measuring output really gives no additional tilt adjustments. However when i meausured while it is on transmitter's MPX input - i needed small tilt correction, just a bit.
So, you always need to check for tilt, no metter what card.
with Juli@ i like simplicity with routing and full Asio support. Full mean.. it will work with every asio version in any software.
Also better driver for 64bit OS. However, i always recommend 32bit OS for dedicated PC for transmitter site (XP or W7 starter/home basic).
