 Post subject: internet connection
PostPosted: Fri Feb 15, 2013 12:23 pm
Why this software (st and perfect declipper) is continuosly connect to internet? (ip 198.187.29.53).
Is this necessary? I don´t understand... I like the privacy when i buy.
Thanks!
 Post subject: Re: internet connection
PostPosted: Mon Feb 18, 2013 6:36 pm
Sorry for not responding sooner. During startup it checks for new versions etc - after that the connection should be closed though. Isn't it???
PostPosted: Thu Feb 21, 2013 9:28 pm
Thanks for the answer. Not is posible disable this check?
PostPosted: Thu Feb 28, 2013 2:47 pm
Like I said, it should disconnect immediately and just do a single request (with only a few bytes of data) to the server. If that's a problem... You could block it in your firewall I suppose.
