 Post subject: New declipper license?
PostPosted: Fri Apr 13, 2012 4:18 pm
" Added support for cheaper limited Winamp/DSP declipper license"
Which are the terms of this license? I don't see any new license in the register page
Thanks
PostPosted: Fri Apr 13, 2012 5:06 pm
http://register.perfectdeclipper.com/
PostPosted: Fri Apr 13, 2012 8:03 pm
Thx
PostPosted: Wed Apr 25, 2012 5:17 pm
OK. So I bought the new license, which implies:
"It plays a short beep at random moments on average every 2 hours".
BUT, I am listening the third song in a row now and in each one of them I've heard a beep. That is a lot less than 2 hours. Overall behaviour is erratic, cause I have yet to hear more than one hour of music without a beep.
PostPosted: Wed Apr 25, 2012 10:22 pm
Ow, that's not good. It should really only beep once per 2 hours on average. You are using version 1.10 or ST 6.30 right? (there was no support for this license in older versions, they will also show Unregistered options in use with this new license).
I'll run a test now.
Edit: Just registered using your license.. Listening...
PostPosted: Wed Apr 25, 2012 10:52 pm
Heard 1 beep after 28 minutes. So that's 1 in the first 30 minutes - could be ok (25% chance of getting a beep in a 30 minute period), or not. I'll let it run all day tomorrow.
PostPosted: Tue May 01, 2012 6:59 pm
Got some proof now also. The link file is a CD a made, so roughly 1 hour and 16 minutes long. I had a beep at. 34:24, then another one at 58:11.
http://www20.zippyshare.com/v/53808343/file.html
PostPosted: Wed May 02, 2012 3:58 am
I don't like it, "beep" should be louder :)
PostPosted: Wed May 02, 2012 4:36 am
You could make a preset for it... :P
...or should we get camclone to do it? :lol:
PostPosted: Sat May 05, 2012 12:31 am
Hans,
There really might be something wrong here. Just got 2 beeps in the same song (not the first time). I know the terms of the license provide that the beeps are in avarege every 2 hours, but 2 in the same song? That seems to stretch them too much. Hope you have some time to check it out, or tell me if I'm wrong and the beep patterns I have described are, indeed, within the license terms.
