PostPosted: Thu Nov 10, 2011 4:44 am
Hello
Can I find a reference to the meanings of the ST front panel graphs that aren't labeled?
Specifically, referring to the two sets of horizontal VU - Above Noise Gate, and Below the Bass Boost indicators...
The top set of graphs -- I see this graph sometimes go Red. Is that a problem?
And, the bottom graph - can I assume this is "final output" VU?
And, in the multiband limiter section, I occasionally see vertical black bars dropping from the top. Is this OK? Is is indicating that I have too much or too little of something?
I'm running with slight tweaks to Bojcha's B-Town settings for reference.
PostPosted: Fri Nov 11, 2011 10:05 am
Top 2 bars: Input level. Red means (potentially) clipped input. Not necessarily a problem, you often cannot fix it anyway (for example if you have a clipped CD or MP3 file).
Bottom 2 bars: Output level.
Black bars from top means that multiband clipping is active. This makes the sound smoother - if it's used too much though it might remove punch and cause the sound to be more 'noisy' (distortion-like).
