PostPosted: Sat Oct 08, 2011 3:12 pm
After many variations and versions this is my RC1 of preset. (used Standalone ST6.20_beta127)
Neodymium_(streaming)_RC1.rar [3.12 KiB]
Downloaded 671 times
If someone finds something sounds distorted or in any way bad, please inform me.
PostPosted: Sun Oct 09, 2011 1:20 am
something went wrong! Loudness is at 0 and pre-amp at 1... etc. :shock:
I might be using other beta version on other PC. No, there is letter 'a' at start of preset.
Correct version!
Neodymium_(streaming)_RC1_FIXED.rar [3.32 KiB]
Downloaded 649 times
PostPosted: Mon Oct 10, 2011 9:16 am
Only comments are that I think that the center frequencies now give this one just a little bit too much upper mids and highs, and maybe not quite enough sub-bass/bass. That could be RMS level differences though, as this is a louder RMS preset than what I just posted. It also has less dynamic range, as measured by that TT Offline DR meter.
PostPosted: Mon Oct 10, 2011 1:27 pm
Yes Brian, that was point with this preset to open as much as possible mid-highs and highs and to stay clean. Also as much as possible highs RMS but to keep dynamics. I already have update with bass which i was't liked too. (still testing.)
PostPosted: Mon Oct 10, 2011 4:03 pm
I'm using your preset, and for my music it had too much bass, so I edited it a bit.
But you can feel the volume rising, when i fade from a very loud track to a very quiet one. It takes about 5 seconds to restore the volume...
PostPosted: Mon Oct 10, 2011 4:08 pm
See.. for someone subbass and bass ar bit lower, for you it's too much. ;)
What are those two tracks ?
PostPosted: Mon Oct 10, 2011 7:18 pm
RMS level makes a lot of difference :P
I'm not sure what they're talking about, but you can use Van Halen - Hot for Teacher, followed by Massive Attack - Dissolved Girl... Dissolved Girl starts out soft. Seems like an ok up speed in that instance, but just make sure you aren't wearing headphones and fall asleep at your computer... 8-)
PostPosted: Mon Oct 10, 2011 9:15 pm
Here's update. More bass (mostly on constant bass sounds), less bass pumping, bit lowered mid-highs and super-highs.
Neodymium_(streaming)_RC2.rar [3.18 KiB]
Downloaded 688 times
PostPosted: Fri Oct 14, 2011 7:15 pm
good job! 8-)
by GAP
"Less is More" (Bob Katz)
PostPosted: Fri Oct 14, 2011 7:36 pm
Thanks G :)
Update again will come...
I forgot to test it with other tests like commercials vs different productions so i had some different rms levels. Also i bring monitor spekers from radio to my home to tweak better some sounds. (don't tell to my boss) :)
so
- Tighter limiting
- even better and tighter bass
- Better preserving RMS
.. is comming.
