I just couldn't believe the 7 dB requirement, and I've Googled a bit on Google adwords
This is what I found:
What is the dynamic audio range?
The dynamic audio range is the difference between the peak and average audio level in your spot. This ratio should not exceed 7dB. Basically, the difference between the peak audio level and average audio level cannot be too large.
So Google's definition does not correspond to what I though and what Wikipedia describes. Also, it is definitely NOT what RightMark measures - RightMark measures the difference between the loudest and SOFTEST part instead of average.
Hint: Open the generated .WAV file in a wave file editor. Or look at the output sliders of Stereo Tool. If the peak level is not more than 7 dB louder than the average level, you're ok.
Hint: To trick Google to broadcast your ad louder, use the Loudness filter...
