Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Thu Sep 08, 2011 1:34 am
There is my preset: LUCIDITY FX4 Beta - What Do You Think Edition.
This is not volume war competitive preset! This is tuned for quality!
Final Version is in StereoTool 6.20 - Webradio - User Presets
I using it for normal listening and occasional webcasting my rokie station. :-)
My way is different from many others. I tuning this profile for high dynamic and clarity. Target dynamic is DR8-9.
- Older songs (like Starship - We Built This City) are decently boosted to DR9-10.
- Modern clipped and compressed song (like Rammstein - pussy) are de-clipped and reduced volume to reach DR7-8.
- Recommended webcast bitrate is 192kbps MP3 or Vorbis at Q3 or higher.
- And little warning: Lucidity FX4 is CPU hungry.
I'm happy with sound which StereoTool 6.20 + LUCIDITY FX4 (beta) produces.
So... there is for everyone! Enjoy it!
And I will be happy when you advise me what to improve in future.
ACHEs_LUCIDITY_FX4_WDYT.zip [3.49 KiB]
Downloaded 871 times
PostPosted: Fri Sep 09, 2011 9:12 am
Pretty good. I like some things in here better than mine/Bojcha's... It seems to do well on most tracks, although I had to disable declipper...
One thing that's present in this that I ran into some time ago on my own is left channel artifacts / warble noise with Rolling Stones - Paint It Black. I got around it by lowering the stereo boost maximum amplification. 1.15 is about the max before I start significantly noticing it. It is possibly just my track of it though.
Paint It Black is also the track I like to use to check for screaming vocals...and yours didn't hurt my ears... 8-)
Beyond that, maybe a bit weak in the bass for hip-hop / rap, although since I turned declipper off, that may be the reason why. The sound I like though is generally heavier on bass...so, subjective evaluation...
Also maybe a touch weak in upper mids to low highs, but I'm not sure, and it may also be subjective. I like toms and snares with a bit more zing... Goes along with the whole emphasis on percussion...
Overall, very nice... Gives me some ideas to work on...
PostPosted: Sat Sep 10, 2011 2:28 pm
Nice! downloaded over 20 times after 2 days + positive response. I did not expect. So, future versions I will upload to the forum as well.
@Brian:
Thanks for your reply.
- I tested the song Paint it Black but I haven't noticed any artifacts. It is old song with a minimum stereo effect: http://www.abload.de/img/0-rolingstonesfuyh.png ... or I not know what to imagine warble noise :-) (I know... my english is bad :-D )
- From my experience, DeClipper has minimal impact on most songs, but just at hip-hop its effect is often audible. For example, here (Jay-Z - Empire State of Mind): http://www.abload.de/img/0-hip-hopkuon.png
On the other hand, DeCplipper kills demoscene music and Gabber ... in these genres must always be turned off! For the hip-hop and similar vice versa.
Plans for future versions:
- Add more Bass :-)
- Tuning of mid to high frequencies, plus better clarity ...
- Control of Stereo-Boost - really makes my settings artifacts?
- Tuning de-Clipper, perhaps deactivation at default - its effect is minimal on most songs.
- If in the future Hanz adds function Undo / De-processing will be included in the Lucidity FX - the effect could be better than De-clipper because most of the songs just are not clipped, but are mostly heavily compressed.
PostPosted: Sun Sep 11, 2011 2:48 am
The question is: do we really have the same song (technically) ?
I guess different remastered versions of this prominent song exist, so maybe we compare apples and oranges.
Besides I like your preset, too.
Especially with speakers it is good (dynamic and open).
Using headphones I agree with Brian that it lacks a little bit bass punch.
And maybe it is not the best choice if you have very heterogeneous playlists (like me).
For example something like "Sophie Ellis Bextor - Murder On The Dancefloor" and then "New Order - True Faith" the loudness difference is noticeable.
But it is for sure a good base for (re-)mastering tasks (using Stereo Tool VST version in combination with other VST plug-ins).
PostPosted: Tue Sep 13, 2011 1:55 am
Now, I testing new version with little more bass, but I don't think there was not enough bass. :-) Maybe I have over-bassed headphones (Sennheiser HD485 + Beyerdynamic DT770. Both headphones play bass well and strongly - Beyers more better :-D ) Maybe it also depends on the genre.
I upload it as soon as passes all of my test songs without easy audible problems.
And thanks for reaction.
EDIT:
Hey... I tried a song Inna - Déja-Vu... Original version is realy ugly... Try it with LucidityFX!!! :o
Version with little more bass sounds good (especially on Inna :-) ), but there is a loss 1dB (TT DR Meter). :cry:
PostPosted: Tue Sep 13, 2011 7:46 pm
Here is new version with little more bass. But I do not think it plays better ... for me the bass levels is too high. :)
But I look forward to your opinions.
File comment: Version with little more bass.
ACHEs_LUCIDITY_FX4_b13092011.zip [3.58 KiB]
Downloaded 676 times
PostPosted: Tue Sep 13, 2011 10:35 pm
What are your bass/treble settings in your sound card software? Mine are set to half on each (50/50). X-Fi Xtreme Gamer.
PostPosted: Wed Sep 14, 2011 1:46 am
soundcard is: Auzentech Bravura 7.1 - with original OAMPs
With DT770 (90% usage) I using this setting: http://www.abload.de/img/dt770q7iq.png = relative neutral. And with HD485 I boosting EQ bands 125 (1dB), 62 (3dB), 32Hz (4dB).
- no any other sound enhancement.
EDIT:
But... Okay... I now neutralize EQ, and tuning it Again! :geek:
New multiband tuning: http://www.abload.de/img/lfx4bb7iq.png - makes bass more punchy a deeper than my first uploaded version. It's maybe handle better with modern songs (Inna souids great!) and hip/hop style... but what old songs? I must test it.
PostPosted: Sat Sep 17, 2011 5:51 pm
Latest version.
- slight multiband tuning
- add 10% bass boost
- reduced loudnes to 0,25dB (for keep same avg. dynamics)
ACHEs_LUCIDITY_FX4_RC.zip [3.56 KiB]
Downloaded 749 times
PostPosted: Fri Sep 23, 2011 11:42 pm
Now, I waiting for final release Stereo Tool 6.20.
Final version Lucidity FX4 is ready for release. Final version is overall better than WDYT edition!
Here's a sample test of the dynamics of some songs: http://h2.abload.de/img/lucidity_fx4_dynamicswb33.png
- It has better Bass and mid-Highs, but same or better dynamics!
- It just sound you'll love! :P
