 Post subject: MicroMPX not connecting
PostPosted: Sat Apr 12, 2025 5:00 pm
i have 2 pcs, one is running stereotool and the other onsite is running MicroMPX.
When i install MicroMPX on the studio pc, and connect from the remote site to the studio its working great.
The other way round, stereotool in the studio and MicroMPX at the transmitter, i cannot get a connection.
Any ideas?
PostPosted: Sun Apr 13, 2025 9:03 am
To be able to connect µMPX from transmitter side to STT in the studio, you need to configure your modem/router with port forwarding and set as UPD, not TCP
PostPosted: Sun Apr 13, 2025 9:21 pm
that should not be the problem, cause they are on the same network
PostPosted: Mon Apr 14, 2025 1:47 pm
if from the when µMPX Decoder is on stutio and STT on remote site it's working then from studio pc to remote pc, it'ok
But when µMpx decoder is on remote PC and STT on studio PC it's not working, that will say remote pc can't connect to studio PC. Verify then the firewall on Studio PC and open port in UDP.
