 Post subject: Prismic (FM - v1.1)
PostPosted: Thu Apr 10, 2025 9:21 pm
No compression and density, tested on ST 10.51
- Declipper
- Noise gate
- Phase rotator
- 6 band Auto EQ
- 3 band legacy AGC
- Normal EQ
- Stereo boost
- Stereo delay
- 6 band limting and 4 band soft clipping
- Bass clipper
- Advanced clipper
Please keep in mind this is for FM and set up for use with the Composite clipper and in our case also Stokkemask.
- Input around -6 dB
- Composite clipper extra drive +1 dB, v1.1: 0 dB
- Audio quality 150% - limitless, follow preset - don't process high frequencies above lowpass filter
File comment: DKR - Prismic v1.1
DKR - Prismic v1.1.zip [222.74 KiB]
Downloaded 246 times
DKR - Prismic.zip [127.42 KiB]
Downloaded 335 times
 Post subject: Re: Prismic (FM - v1.1)
PostPosted: Sat May 10, 2025 1:03 am
v1.1 - Adjustments all over and no more use of the EQ.
Inside the ZIP are screenshots for the Audio Quality, Composite Clipper, RF Bandwidth Limiting and CPU usage settings.
Because the strictness of the Composite Clipper is set low to avoid (as much as I could) distortions, I would advice
to use RF bandwidth limiting (Stokkemask) just to be sure to keep within limits, the preset is adjusted for use with it.
Also because the Composite Clipper strictness is low, the preset is quite friendly on CPU usage (on our PC below 12%)
