PostPosted: Sun Feb 09, 2025 10:09 pm
Trying to get rid of the echo and spurious sounds that are forever present in all the presets I've ever tried. This has been tested on a small speaker comparing to live radio at same time + headphones so should be smashing for that, not done the vehicle test yet.
Anyway hope you like it. :)
Glaswegian Smasher - by DanS V2.sts [176.34 KiB]
Downloaded 282 times
PostPosted: Fri Feb 14, 2025 1:16 pm
Nice one, but why clipper on band4? and 11kHz LPF ?
PostPosted: Fri Feb 14, 2025 9:32 pm
It seems that band 4 wouldn't behave itself on some music... so I made it :lol:
Actually I don't know some tracks had a bit more echo coming through on that one but you can take it off to make it more open and use feedback2 sometimes to sort it out or just turn down the level by 5-10db in MB.
Also I've noticed that on commercial and even bbc stations is there isn't much frequencies coming through after 11khz. Depending on the stereotool preset it can sound better if there are too much highs. But if your personal preference is higher that's up to you I guess. :)
