PostPosted: Wed Jan 08, 2025 3:56 pm
Are we reaching a point where the constant stream of beta releases (10.01, 10.11, 10.21, etc.) is overshadowing stable versions? Should users be concerned about relying on beta software for critical broadcasting, or is this just the new normal for rapid innovation?
PostPosted: Wed Jan 08, 2025 6:22 pm
The versions that you mention are all release versions, not beta versions!
PostPosted: Fri Jan 10, 2025 3:38 pm
I encourage you to read up on semantic versioning.
