PostPosted: Sat Dec 28, 2024 3:43 am
Hi, it would be appreciated if it was possible to send <0D> after the radiotext, so receivers which show A and B can have it centred. I am not sure if this is possible already.
PostPosted: Mon Dec 30, 2024 3:28 pm
We used to do that but multiple receivers don't seem to understand it at all and they didn't display any RT at all anymore. At least, not in the way we implemented it: After the <0D> you should be able to stop transmitting any further data. It might be worth trying to fill the full 64 bytes with <0D>'s or spaces, but I need some help for that from someone with a receiver that has problems with this.
Currently the <0D> has been disabled just to prevent issues with the receivers that don't properly implemented the standard.
PostPosted: Tue Dec 31, 2024 9:16 pm
As I remember, I saw <0D>'s one after another 2 or 3 times at the end of the text with older versions of Stereo Tool (RDS Spy shows it), while other stations sends <0D> only one time at the end of the text, and starting with the first character of RT again.
It would be nice to have this function working correctly, shorter texts would be shown faster.
PostPosted: Sat Jan 18, 2025 7:26 pm
yup I agree!
PostPosted: Thu Oct 23, 2025 11:27 pm
@hvz, I think it would be nice to have the option, maybe in advanced settings?
