PostPosted: Wed Aug 28, 2024 6:06 pm
Hello
I have StereoTool and Watchcat both licensed properly. When I try to select a stereotoolpreset to apply the drag and drop-feature, I get a message that it isn't properly licensed. I have a proper license both on WatchCat and Stereotool.
Any idea?
PostPosted: Thu Aug 29, 2024 3:20 pm
Hello
Any idea?
Yeah, this is a bug. I believe you can do some trickery to make it accept if you resize the window and try again. I've told Tom and Hans about it, but it doesn't seem to have made it into the list of things to fix in the beta threads. I'll forward this thread to them though.
PostPosted: Thu Aug 29, 2024 5:05 pm
OK. But the question is: will it matter? Will there be a tone/message superimposed on the track or will it work?
PostPosted: Thu Aug 29, 2024 6:30 pm
There shouldn't be problems regarding Stereo Tool processing. I've processed tons of junk after dismissing that mistaken popup via resizing the window. I don't own Watchcat so I can't speak for that aspect.
PostPosted: Fri Aug 30, 2024 11:56 am
Hi, this issue should have been solved in the latest beta's. You can get them here: https://forums.stereotool.com/viewtopic ... 14&t=34069
PostPosted: Sat Aug 31, 2024 10:07 am
Thank you. Will try.
Regards
Erik
