PostPosted: Thu Aug 01, 2024 1:26 am
v1.23
Tested on ST 10.40
Input level: best around -6dB
Composite clipper: Extra drive 1.6dB
Audio quality: 150%
limitless, follow preset
don't process high frequencies above lowpass filter
I would advice to also load the Repair settings (Noise Gate, Declipper)
You might have to adjust the Processing pre amplifier to your desired level.
For other than FM broadcast use you could lower the Bandpass Highpass to 30Hz and loosen the Bass Clipper a bit, strictness to factory default and Overshoot softness to 0.5 - 1.0.
File comment: DKR - HOT4RAC - v1.23
DKR - HOT4RAC - v1.23.zip [127.78 KiB]
Downloaded 329 times
PostPosted: Fri Aug 16, 2024 2:14 am
New version up, many changes, probably final.
I tried to make the processing as invisible as I could with some dynamic range and very little distortion, only louder and wider.
You could go even a bit louder by raising the Advanced Clipper drive about 1dB more.
Should have a quite "friendly" AGC, so tracks with a fade in/out still have some.
For other than FM broadcast you could set the Bandpass Highpass about 10Hz lower and the Bass Clipper Overshoot softness to about 0,5 for a bit more (deeper) bass.
You might have to adjust the Processor Post amplifier to your desired level.
Comments always welcome, would be nice if there's somebody who could test it on their transmitter.
There must be users that like some nice RAC ;) (Rhythmic Adult Contemporary)
PostPosted: Sat Aug 24, 2024 10:30 pm
v1.11 Final.
Some minor changes to MB1 (band 3 clipper/limiter, band 4 release/release shape)
PostPosted: Fri Nov 15, 2024 5:03 pm
One . two three, a new recipe.
Now with added Auto EQ and Noise Gate flavor and a sprinkle of Phase Delay and Reverb.
