PostPosted: Tue Jun 11, 2024 10:59 am
Select multiple presets by means of ctrl click and ctrl + a to delete all loaded presets at once
PostPosted: Tue Jun 11, 2024 11:02 am
Alternatively they can be deleted from the folder located at C:\Users\Administrator\stereo_tool.presets
PostPosted: Tue Jun 11, 2024 12:47 pm
I'll bring this up to Tom.
or simply Win+R to open the run box, then:
%USERPROFILE%\stereo_tool.presets
Some folks arent administrator or don't have their user folder on C drive
PostPosted: Tue Jun 11, 2024 10:18 pm
Yea, when that foleder has zillion files, ST startup is super slow. very bad.
PostPosted: Wed Jun 12, 2024 12:05 pm
We'll look into it
PostPosted: Wed Jun 12, 2024 12:18 pm
I've put this on our todo-list, but it might be a while. In the meantime, removing the files manually seems like a reasonable workaround to me.
