 Post subject: uMPX decoder on Linux
PostPosted: Sun Oct 15, 2023 7:37 pm
Just updated an rpi running a uMPX decoder to Bookworm.
I want to be able to use the read-only overlayfs but when enabled, uMPX decoder re-enumerates the ALSA devices and misses the one that was stored in its last configuration. I see this on a live environment and can't do much further testing now but it also occured with a read/write boot.
Is there any way to pin the FM output to the ALSA name rather the ALSA numbers? (the name doesn't change):
card 4: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 [HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0]
The device changes its card id between 2,3 and 4 .
PostPosted: Mon Feb 24, 2025 1:41 pm
It's already stored by name, not number. So if the name doesn't change, it should work...
PostPosted: Tue Mar 04, 2025 4:14 pm
indeed I've never encountered the problem again. So consider this resolved. Thanks.
