 Post subject: Numeric ITU
PostPosted: Fri Sep 22, 2023 5:55 pm
First off: the new ITU (LUFS) meter in 10.10 is really a great leap forward. But I would like a numeric value like 11.4 instead of "around 11". Also adding loudness range and dynamic range would be great to have. I use Youlean to measure the signal, but with the new 10.10 version, I only need to use Youlean to get more precise readings. So I'm happy with this. But would be even more happy if I got a numeric output instead of bars. I'm just saying.
 Post subject: Re: Numeric ITU
PostPosted: Fri Oct 27, 2023 7:28 pm
That's a good idea, I've added it to our (long - so I can't promise you when we'll look into this) todo list.
PostPosted: Fri Dec 08, 2023 4:58 pm
Something like this..
https://i.imgur.com/BVffMTz.png
Integrated bar not needed, Those two bars can now measure 2 short terms.
PostPosted: Fri Dec 08, 2023 6:38 pm
I can't remember; how long does the integration back buffer keep? Is it the entirety of the time between resets? Could that bar be set at one to three minutes if the full program integration value is shown numerically?
