PostPosted: Sun May 14, 2023 3:35 pm
Hi, stereo tool stand alone users with behringer u-phoria umc202hd as input which vistual sc you are using as output? I experience audio issues with Vb-Cable after a few hours
streaming normally, i have tried all the sync options in st, right now i run test with VSC.
PostPosted: Thu Oct 03, 2024 10:22 pm
here its just running with virtual audio cable, sure its not just some other program taking control over the device? or maybe ASIO4ALL if thats present on your system?
i had issues with asio4all and vab
Studio Pinokkio Friesland (Frisian, Netherlands)
Specifications of our station:
Suono ESVA 100, RvR PJ1000m
Behringer UMC soundcard, Dateq LPM 7.3
StereoTool 10.21
PostPosted: Fri Oct 04, 2024 4:16 am
Always check VB cables for samplerate in windows both inputs and outputs (playback / recording), they know to be different, and ofc should be same.
