Post new topic  Reply to topic  [ 63 posts ]  Go to page 1 2 3 4 57 Next
 Post subject: BigFlex6 HD/FM
PostPosted: Wed Oct 12, 2022 1:47 am
BigFlex6_v0.7_BojchaHD.sts [466.78 KiB]
Downloaded 1059 times
BigFlex6_v0.9_BojchaHD.sts [412.14 KiB]
Downloaded 814 times
BigFlex6_v0.10_BojchaHD.sts [466.91 KiB]
Downloaded 861 times
BigFlex6_v0.13B_BojchaHD.sts [412.18 KiB]
Downloaded 1047 times
Probably final version.
BigFlex6_v0.19_BojchaHD.sts [412.22 KiB]
Downloaded 1542 times
BigFlex6_v0.19_BojchaFM.sts [438.58 KiB]
Downloaded 1318 times
- If you need more or less range in AGC, simply go to AGC and adjust 'Drive'. It depends on your input level.
- Preset use low range in MB, so if you need more spectrum control, just enable 'Auto EQ'. (not recommended)
- BASS: If you want less or even more bass, i make it easy, go to MB2 and adjust 'BandMix' of band1. Normal range for that settings would be -3 to +3 where 0 is kinda normal, but it really depend on type of music and personal taste. 0dB is really neutral.
- IF you need it to be louder, best would be to rise MB2 output (not recommended)
- For that optimod non-linear flavor sound, just turn ON "Phase Delay", all adjusted, - it'll also clean some source and processing distortions.
- Tip: Always use "Don't process highs", for some reason that thing fixes almost all artifacts in Deep BASS! + 130-150% "Audio Quality" - Sane. Thanks to Beneyto for asking me to test this. In the same time do not use LPF more then 18200 exactly. For FM you will not have calibration so turn it OFF if you need FM calibration.
* For FM version best would be to "Load all audio and FM settings" - however it will reset your RDS settings so be sure to have backup.
Final version (pack)
Pack contains 3 versions - HD, FM and HD -12lufs.
Many changes in Final version, much more consistant rms level, super protection for loud bursts - kinda bullet proof, spectrum redefined (much more open, yet much processed), better punch in clipper, better ND.. many small changes everywhere!
BigFlex6_Final_Bojcha.rar [348.26 KiB]
Downloaded 1847 times
-_-
 Post subject: Re: BigFlex6 HD
PostPosted: Wed Oct 12, 2022 2:06 am
Maximum low-end that i can stand and cleanest as possible.
let me know..
Nice!!! I will test it tonight. This preset is now in your "control point"?
https://fmfeeling.com
PostPosted: Wed Oct 12, 2022 2:21 am
let me know..
Yes it is :)
PostPosted: Wed Oct 12, 2022 2:34 am
Last night I've listening that stream and I was impressed by the sound and today I was to ask about it... Good job!!! BTW: see the highs deeser in advanced clipper with FM output, come back the yellow bar, IDK if is intentional or not. Your preset is air FM in my station now... it sounds wonderful...
PostPosted: Wed Oct 12, 2022 3:00 am
Ah i use old ST version (enterprize) so i can have working Input2, there you cant disable de-esser so it left like that.
Also i didn't check FM levels and HardLimit is off, so be carefull.
PostPosted: Tue Oct 18, 2022 2:17 pm
let me know..
I am trying to make it to fit many sources, so download latest one.
- Preset use low range in MB, so of you need more spectrum control, just enable 'Auto EQ'.
- If you want less or even more bass, go to MB2 and adjust 'BandMix' of band1.
- IF you need it to be louder, best would be to rise MB2 output, but for HD i don't recommend it.
BigFlex6_v0.13B_BojchaHD.sts TOP for my radio www.radioinsomma.it ;)
PostPosted: Tue Oct 18, 2022 6:43 pm
Ty, it helps to see how it's going on multiuple sources. However something is wrong with your stream, you are pushing much over 0dB for some reason or you badly changed something in preset.
PostPosted: Tue Oct 18, 2022 10:54 pm
Glad you're back on it! Excited to try this one out!
PostPosted: Wed Oct 19, 2022 11:07 am
I lowered the level of the RadioBoss input .. I use the SSL2 card to stream out with the 4K legacy keys inserted and then the level exceeded 0db. Anyway thanks ... and greetings from Naples! ;)
PostPosted: Tue Oct 25, 2022 10:47 pm
Hello. Here's how it sounds to me. v0.13 https://securestreams4.autopo.st:1826/grmljavina.m3u I didn't change anything in the settings. It is exclusively an Internet radio. I don't think it's bad, although maybe in some songs the guitars seem sharper than they should be.
