PostPosted: Tue Oct 11, 2022 4:05 pm
Today we need to use VPN or have ports open on the decoder side in order to get access to encoder stream. Is it possible to have an option to have it the other way around?
Encoder: fixed adress exposed to internet. Open ports for each decoder/destination.
Decoder: type in adress of encoder and port. In this was the decoder can be behind a firewall without fixed ip adress. On the second nic maybe a mobile broadband modem can be used.
Remote control: Simple proxy so that we can control the decoder from the encoder side.
Kind regards,
Alf Ivar
PostPosted: Mon Dec 12, 2022 11:40 am
I agree with you. I've always found it weird it this this way and now the other way around.
PostPosted: Fri Dec 16, 2022 11:39 pm
You may want to consider Tailscale.
They use WireGuard as a transport and will make best effort to get peer to peer connections, falling back to a bounce server if both ends of the connection don't have public addresses or firewalls are too strict.
