 Post subject: tidal
PostPosted: Tue Feb 08, 2022 2:29 pm
my new tidal settings
tidal.sts.zip [120.92 KiB]
Downloaded 723 times
 Post subject: Re: tidal
PostPosted: Fri Feb 18, 2022 9:46 pm
this is great! thanks for sharing
PostPosted: Sat Feb 19, 2022 9:08 pm
Good preset!!! Thanks!
https://fmfeeling.com
PostPosted: Sun Feb 20, 2022 10:24 am
Which version of ST are you using? When loading this one in version 9.83 the complete sound is stuttering. :shock:
PostPosted: Mon Feb 21, 2022 6:08 am
Latest beta... 9.84b26
PostPosted: Thu May 26, 2022 10:47 pm
Hello. The preset is good, but it seems to me that equalizing the volume of the songs doesn't work very well. Some songs that were quiet were not amplified during playback. I only used the load audio option to load this preset. I didn't load all the settings because my radio only goes over the stream. Is that perhaps the problem?
PostPosted: Fri Jun 03, 2022 3:40 pm
Love it! Subtle goodness! No fatigue so far
