 Post subject: Delossifier and .ogg
PostPosted: Tue Feb 01, 2022 5:29 pm
Hello
we use ogg files with our own webradio software, radiocaster, icecast2 on a VPS.
Ogg files are songs, our voices, ...
Delossifier is it useful with ogg files tracks or it is only for mp3 tracks ?
Many thanks !
 Post subject: Re: Delossifier and .ogg
PostPosted: Wed Feb 02, 2022 11:32 pm
Looking at some spectrograms, it appears that the lower the OGG Vorbis quality, the more spectral gaps are there for the Delossifier to fill. However, nothing beats a real-world test. You can always enable the Delossifier in trial mode and the Spectral Hole Filler and take a look at the difference in its built-in spectrograms.
The answer is yes; but really, it depends on how compressed your ogg files are and with which codec. There appear to be FLAC and Opus encoders for ogg containers in addition to the older Vorbis. So if you're using one of those encoders, the spectral loss might not be much of a factor.
