PostPosted: Thu Dec 23, 2010 10:41 am
Hello, everybody !
Here is my favourite preset. It allows Winamp to play music with a very constant volume, very heavy trebles, some loudness and a bit little basses.
I'm waiting for your comments.
Here is the code :
[Common]
Pre amplifier=10
Post amplifier=0.930000007
Extra loudness=2
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.224999905
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.000149978
Decay speed=0.01500234
Above Top Limiter=0
[Pre Compressor]
Enabled=0
Maximum volume - Band 1=35000
Attack speed - Band 1=0.000005
Attack speed - Band 3=0.000005
Decay speed - Band 1=0.00025
Decay speed - Band 3=0.00025
Dual band=1
Third band=0
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=3
Relative maximum volume of very highs=0.330000013
Remove remaining peaks above (relative to maximum volume)=1.75
Enable smoothing=0
Smoothing time=10
Gating level=0
Use ITU-BS.1770=0
Channel separation=0.300000012
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=2540
Maximum volume - Band 0=2540
Maximum volume - Band 1=5080
Maximum volume - Band 2=5080
Maximum volume - Band 3=5080
Maximum volume - Band 4=5080
Maximum volume - Band 5=5080
Maximum volume - Band 6=10000
Maximum volume - Band 7=10000
Maximum volume - Band 8=10000
Attack speeds linked=1
Attack speed - Band -1=0.000019993
Attack speed - Band 0=0.000019993
Attack speed - Band 1=0.000019993
Attack speed - Band 2=0.000019993
Attack speed - Band 3=0.000019993
Attack speed - Band 4=0.000019993
Attack speed - Band 5=0.000019993
Attack speed - Band 6=0.000019993
Attack speed - Band 7=0.000019993
Attack speed - Band 8=0.000019993
Decay speeds linked=1
Decay speed - Band -1=0.003999895
Decay speed - Band 0=0.003999895
Decay speed - Band 1=0.003999895
Decay speed - Band 2=0.003999895
Decay speed - Band 3=0.003999895
Decay speed - Band 4=0.003999895
Decay speed - Band 5=0.003999895
Decay speed - Band 6=0.003999895
Decay speed - Band 7=0.003999895
Decay speed - Band 8=0.003999895
Above Top Limiter=1
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=3
Relative clip position - Band 0=3
Relative clip position - Band 1=2.508771658
Relative clip position - Band 2=1.985074759
Relative clip position - Band 3=1.985074759
Relative clip position - Band 4=1.985074759
Relative clip position - Band 5=1.985074759
Relative clip position - Band 6=1.985074759
Relative clip position - Band 7=1.985074759
Relative clip position - Band 8=1.985074759
Final limiter value=0.599999964
Final limiter decay speed=0.4977763
Final limiter clipping=1
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=0
Image width amplifier=0
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=5
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=20
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title% "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - http://www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
latloud.zip [2.22 KiB]
Downloaded 944 times
