 Post subject: Preset: audio only?
PostPosted: Sun Sep 15, 2019 8:03 pm
When choosing a ST preset, I only want audio settings changed, not FM (since I usually do this live). Where do I select this?
 Post subject: Re: Preset: audio only?
PostPosted: Wed Sep 18, 2019 2:07 pm
I think the easiest way for you is to find all the ST presets you want to use and save them. When saving ST presets I use the original name with -MOD.
Save options are: FM Settings | All Audio Settings | All Audio & FM Settings | All Settings (Export)
Now you can open these the way you want...
Load options are: FM Settings | All Audio Settings | All Audio & FM Settings | All Settings (Export)
PostPosted: Wed Sep 18, 2019 7:31 pm
Hi Beej6! I was under the impression the type of preset selection would only affect things it needs to affect. Like choosing a Generic preset or one from Web/DAB/HD wouldn't affect the FM section, etc?
My personal preference is to turn off limiters and clippers and let Breakaway handle peaks instead, once i've got a preset loaded. I almost wish I could lock those values in place so the preset couldn't change them.
PostPosted: Thu Sep 19, 2019 9:33 pm
That's what I'm hoping, MrKlorox. I'll find out soon... Thanks all!
