 Post subject: input de-empahsis
PostPosted: Tue Nov 06, 2018 3:50 pm
it would be great to have this feature since there are some input sources that are emphasized at 50/75.
 Post subject: Re: input de-empahsis
PostPosted: Tue Nov 06, 2018 4:00 pm
Why would an input be emphasized? Is your input coming from an FM receiver or something?
PostPosted: Tue Nov 06, 2018 7:57 pm
it is a 64Kbit CBR mono MPEG audio layer 1/2 stream that is encoded from the pre-emphasized output of their sound processor for their LPFM radio station (WXNZ), its not my stream or radio station.
also, i occasionally use an RSP2 receiver with variable RBW, the demodulated pre-emphasized FM audio at 150Khz is raw and fed to ST using 16Khz filter on ST.
not sure if any of this makes sense to you but my primary use and function of ST is mainly used at a peak limiter and clipper for my sound system.
i just use the following:
3-band AGC
MB1
Clipper
