 Post subject: Opinion on the sound
PostPosted: Fri Mar 30, 2018 5:53 pm
Hi guys,
I'd like to ask you for your opinion on the following samples.
I've constructed a new preset for modern and clear sound and now I need a few hints or tips from you :). I chose some AC stuff for easy comparison.
These were recorded from the air and de-emphasized:
Phantom Planet - California (Tchad Blake Remix)
Eminem - Stan
Lynyrd Skynyrd - Sweet Home Alabama
Fun - We Are Young
Shakira - Waka Waka
Sixpence None The Richer - Kiss Me
MGMT - Me and Michael
Queen - Bohemian Rhapsody
EDIT: Just noticed that this thread would actually fit better inside the "Can you listen to my stream?" category.
 Post subject: Re: Opinion on the sound
PostPosted: Sun Apr 01, 2018 2:28 am
If it's for FM, MPX recording would be better.
PostPosted: Sun Apr 01, 2018 6:27 pm
I got some MpxTool recordings... (Level not calibrated)
Download
Another one
PostPosted: Sun Apr 01, 2018 6:54 pm
As I thought, your mpx files now does not match to recordings above.
I hard excessive bass wich is not present in MPX recording nor possible to comply 75kHz.
PostPosted: Sun Apr 01, 2018 7:13 pm
Who said it has to comply ;) JK
I just got home and checked the files.
You're right, theres some really deep bass going on which is not in the MPX recordings.
I don't know where that came from or how it snuck itself into the files as it's only audible there.
PostPosted: Sun Jul 22, 2018 11:22 am
Wow. Impressed. Really enjoyed the Skynard but the others sounded great too. I really like the punch you get from the bass. What setting have you found that aid in that? Thanks!
