 Post subject: OCX plugin
PostPosted: Wed Nov 08, 2017 3:34 pm
it would be nice if there could be an option to add an OCX plugin of choice for ST.
for example, there are some "interesting" Winamp plugins that i would like to use to alter the incoming sound to ST before ST processes the sound (soundcard input > OCX plugin).
one of these plugins is called "Center Cut Plus", it is extremely effective at its designed intention, i use it to "alter" the sound of music which in turn, makes that music sound very different than it originally sounds.
the effect of this plugin is very similar to listening to only the center channel in a 5.1 surround system but by using only 2 channels as the source.
i know ST can perform a similar operation under "stereo image" but the functions are limited to what you can do.
thanks.
https://github.com/imrekoszo/centercutplus/releases
