 Post subject: Channel Delay
PostPosted: Mon May 26, 2008 9:45 pm
Where is the channel delay option in 3.10? I use Stereo Tool mainly to listen to mono recordings in stereo. I upgraded from 2.05 and can't find the channel delay option. In online Help is shows the old option as if it's still in 3.10. Am I just overlooking it?
Many thanks,
Msilvers
 Post subject: Re: Channel Delay
PostPosted: Mon May 26, 2008 10:56 pm
Oops - I removed it because of a lack of space... Thought no-one was using it anyway... Apparently I was wrong about that.
For now, get the 3.03 version at http://www.winamp.com/plugins/details/221526 - that version still contained the channel delay.
I'll look if I can still add it somewhere (I removed it when I added the noise reduction).
PostPosted: Tue May 27, 2008 12:51 am
:) Thanks for the quick response. I downloaded and installed 3.03 and I'm back in business.
One other request: when you add Channel Delay back into a new release, could you please:
1. add back a preset for it like the 2.05 release had
2. let me know when you think you'll be releasing the next version that will include these items.
As for use of Channel Delay, I have several mono recordings, either because they are old (originally on reel to reel tapes) or recent that came from mono sources (Internet, TV simulcasts, etc.). It's nice to have something simple that gives them some stereo separation, concert hall type improvement.
Much appreciated!
Msilvers
PostPosted: Tue May 27, 2008 3:01 am
I think I've found a place where I can put it. Will look into it asap.
PostPosted: Tue May 27, 2008 10:58 pm
(Updated May 28th 20:20)
It's not finished yet, but for a "sneak preview" see:
http://www.stereotool.com/_TEMP/dsp_ste ... 080527.dll
In Basic mode you can use "Fake Stereo". In Advanced mode you can set the channel delay.
Note: You need to turn the Stereo image processing on (it's part of the Stereo Image processing now). Also, there's no preset yet.
Hans
____
PostPosted: Thu May 29, 2008 1:09 am
Version 3.11 is ready. Also includes some bug fixes. Go to the download page to download it.
PostPosted: Thu May 29, 2008 2:15 am
:) Works great thank you, and I see you put the preset for fake stereo back in. I'm listening to a 1935 movie's soundtrack music now. Appreciate your fast turnaround too.
Thanks again,
msilvers
PostPosted: Thu May 29, 2008 12:22 pm
Greetings.
v3.11 was released after your post whcih has the channel delay back.
Go to http://www.stereotool.com/download/ to download it.
regards
PostPosted: Wed Mar 18, 2009 6:21 pm
Hello everyone, I'm new here.
I have a question. Is the MPX from Stereo tool is real? I mean is it real the channel seperation, 'cause when I hear it on my FM receiver I get a fake stereo (delayed channels) but not the real stereo sound. Can somebody tell me where's the problem?
Thanks in advance.
PostPosted: Thu Mar 19, 2009 12:32 pm
Getting delayed stereo instead of real stereo with MPX is actually not possible.... Could you check with the "FM Configuration" settings if - when you select "Test - right channel silence", if you do indeed get (near) silence on the right channel?
Also try "Similar, but only using 23-38 kHz" and "38-53 kHz" - if the 23-38 gives good channel separation, but 38-53 does not, your sound card is probably unable to handle the 176.4/192 kHz sampling rate.
If you do get silence but it isn't good enough, you could try changing the calibration sliders to accommodate for any differences.
