 Post subject: TMC FM
PostPosted: Sun Sep 10, 2017 8:37 pm
Straight forward preset that uses the free portion of Stereo Tool 8.23.
Pretty dense, crisp and wide over the top preset with a hit sound.
Let me know your thoughts and suggestions!
Silvan
TMC FM v1.sts [87.24 KiB]
Downloaded 1239 times
 Post subject: Re: TMC FM v1
PostPosted: Sun Nov 05, 2017 3:31 pm
Updated preset, bit louder and more consistent low frequencies. Enabled noise gate, moved to 9 bands on Multiband 2 to get tighter band limiting, enabled Auto EQ and some overall fine tuning.
TMC FM v2.sts [101.83 KiB]
Downloaded 1091 times
PostPosted: Sun Oct 20, 2019 10:18 pm
Meanwhile the preset evolved into version 7 which is now divided into a dense and less-dense version (all down to multiband speeds).
In any case the presets are for a warm steady sound.
Have fun with it. Any comments are welcome.
TMC FM v7 ST935.sts [108.07 KiB]
Downloaded 927 times
TMC FM v7 ST935 dense.sts [108.07 KiB]
Downloaded 1048 times
PostPosted: Sat Nov 02, 2019 8:28 pm
Just wanna say that this preset is great.... We are using the dence version of it right now on Radio Freja. And the open version og Radio Freja Chill.
Great work :D
Thanks and nice to hear! For me just a fun thing to do. Will post updates when they appear.
PostPosted: Mon Feb 06, 2023 8:53 am
Thanks! My search for an (almost) good all-round preset is now over.
I just added Natural Dynamics, Stereo ACR, Declipper, Delossifier (default settings) and True Bass (SubBB).
It's been hard to find to find that sound where vocals are crisp and the stereo effect is real, but here we are with the dense version (plus mods). So if that's what you're after, this preset is definitely is worth a spin.
Thanks again!
PostPosted: Fri Jun 09, 2023 1:56 pm
Thanks for positive feedback. I am reposting the dense preset including TrueBass etc as generated with ST992.
If you want stereo to go really nice and friendly, enable Matrix Mode on the AGC with L+R Boost set to +2.0, and eventually disable Stereo Boost after.
TMC FM v7 ST992 smooth.sts [133.09 KiB]
Downloaded 421 times
TMC FM v7 ST992 dense.sts [133.1 KiB]
Downloaded 500 times
