Post new topic  Reply to topic  [ 12 posts ]  Go to page Previous 1 2
 Post subject: Re: Channel Delay
PostPosted: Thu Mar 19, 2009 7:57 pm
I'll try that, thanks!
And how can I connect the output of my souncard with the FM mono transmitter? Is there any difference wich L or R out should I connect?
P.S My soundcard is Realtek HD. And I get the 19 kHz pilot tone on my reciever.
PostPosted: Fri Mar 20, 2009 12:58 pm
That shouldn't really matter. When using a single channel, the volume needs to be set twice as high, which might cause some pops in the sound (if you broadcast silence on one channel, you might hear some soft pops), depending on the quality of your sound card. Two channels on the other hand might have a phase shift problem, which will cause some loss of very high frequencies (which can be repaired using the FM Calibration window).
BTW, for the Realtek card, check the help pages - there's a remark on enabling 192 kHz mode there (see http://help.stereotool.com/fm_transmitt ... card.shtml ).
