PostPosted: Thu Nov 03, 2022 1:48 am
In this opportunity I share my preset to be able to use it for all kinds of sounds, it is excellent to keep the volume level of youtube videos constant, twich etc. I would like you to give your opinions regarding the preset, I spent hours adjusting the agc to make it more transparent and have almost no difference in level, I hope you like it. It only uses AGC, Power Bass, Stereo Boost, Equalizer, Multiband1 and Hard Limit.
It's for v8.23 and up.
stereotool1.zip [91.63 KiB]
Downloaded 648 times
Downloaded 497 times
PostPosted: Fri Nov 04, 2022 12:14 pm
tnks for sharing (Koempel Radio dutch)
PostPosted: Fri Nov 04, 2022 1:45 pm
Will keep you posted! Thanks for the presents 🙏
PostPosted: Mon Mar 13, 2023 12:06 am
Update:
Well I have modified my preset to make it sound a little better, more controlled and with more density, I managed to make the AGC as transparent and constant as possible by making it maintain the dynamics of the sound a little more, several settings in the compressor, more constant bass , phase rotator and various improvements.
I would like your feedback on how this preset sounds, I may need to make further adjustments if necessary.
densepreset.zip [106.91 KiB]
Downloaded 598 times
