PostPosted: Thu Oct 24, 2019 1:29 am
Cannot get the RDS PI code to update in the web console, have ST running as a service so making it difficult to set the PI code correctly now that it is live, suggestions?
PostPosted: Mon Oct 28, 2019 10:44 am
That web interface can be a bit picky when typing in text, make sure to click some other button / text field / checkbox, and then it will update what you typed in the textbox before.
PostPosted: Mon Oct 28, 2019 1:09 pm
Thanks, i did try everything I could to get it to update, looks like it works on every other field except for the PI code field, I even checked the debug tools of the browser, the others all show the update process on blur focus, but not the PI field, ended up having to stop the service, launch the main app then change there and revert back to service.
