Post new topic  Reply to topic  [ 982 posts ]  Go to page Previous 193 94 95 96 9799 Next
PostPosted: Wed Dec 15, 2010 12:41 pm
Sound from version BETA75 is back:
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 510-79.exe
Stand alone version: http://www.stereotool.com/download/ster ... 510-79.exe [FAILED DUE TO DISK FULL ERROR - SORRY....] --> For now please use this version instead (if you load a preset or press RESET, 'Filter' is DISABLED instead of ENABLED in this version): http://www.stereotool.com/download/ster ... 10-79A.exe
VST version: http://www.stereotool.com/download/vst_ ... 510-79.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 510-79.dll
Command line version: http://www.stereotool.com/download/ster ... 510-79.exe
Linux command line version: http://www.stereotool.com/download/ster ... BETA510-79 (not available)
Linux GUI version: http://www.stereotool.com/download/ster ... BETA510-79 (not available)
QUESTION:
- Is the new 'Filter' checkbox needed? If you turn it off the CPU load for Loudness is 5% lower. I went back to the exact same sound as BETA75 due to the complaints - but if this filter isn't needed I'ld rather turn it off (or at least disable it _by default_).
PostPosted: Wed Dec 15, 2010 11:41 pm
Well , Hello Hans ... Bojcha
Here is the video :
http://www.mediafire.com/?l1h4wgknc34gnnu
Download and watch :
Problem is that filter operation is dependent on input Sample rate .. make it fixed( downasampling ) at 44.100 whatever the input rate is .. and all will be good . Trust Me . Now filter operates at different SR`s and in 192000 is the best option. But in DSP ands VST from where will come 192000 ? In other words : filter must work with fixed SR but to work as is now- STRONG AND GOOD ! I think that SR of filter isn`t affect the work , structure and the most important - Quality of the filter .
from 12000 Hz above.... to 15000 Hz "problem" is bigger and bigger.
And remember.. filter structure is much stronger than Chebyshev 10th order . Good work boys. I believe that this filter is corresponding to Chebyshev 15th order ...... something like that .
PostPosted: Thu Dec 16, 2010 12:08 am
QUESTION:
79 is a good one.
using only 13-16% CPU
had to reduce latency to 2048 otherwise a wee bit crackling
notice that upper wave display is almost flatlined not sur eif this means anything or not
AGC is great
PostPosted: Thu Dec 16, 2010 1:06 am
Here is the video :
Ok, I'm going to check this one... Looks bad!
Edit: Ok, at both 176400 and 192000 Hz it works perfectly. At lower freqs it doesn't. This must mean that the filter itself is good, but something weird is happening. Will try to find it asap!
Edit #2: Found & solved! The filter that upsampled incoming audio to 176.4 or 192 kHz was configured incorrectly (that's why 176.4 and 192 kHz input sample rates functioned correctly). This caused both artifacts and (very very small) spikes in the audio.
PostPosted: Thu Dec 16, 2010 2:42 am
- Audio quality: Turned one filtering step off in 'very strict' filtering mode.(*)
- Fixed Bojcha's preset (see Bojcha's post)
- Fixed DJ-Doggy's lowpass filter issue (see DJ-DOGGY's post)
- Improved Voice vibration filtering at low latency settings. (may cause slightly reduced bass levels, especially at 512 sample latency).
(*) I've done a VERY VERY quick quality comparison and in the (one!) track I compared I didn't hear any difference. Still, due to the removed filtering step, the waveform that comes out is quite different from that of BETA79 (only when using VERY STRICT filtering mode!). Feedback is welcome!
Uploaded incorrect version (BETA80) before, now replaced by version BETA80A - Sorry!
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 10-80A.exe
Stand alone version: http://www.stereotool.com/download/ster ... 10-80A.exe
VST version: http://www.stereotool.com/download/vst_ ... 10-80A.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 10-80A.dll
Command line version: http://www.stereotool.com/download/ster ... 10-80A.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA510-80A (not available)
Linux GUI version: http://www.stereotool.com/download/ster ... ETA510-80A (not available)
PostPosted: Thu Dec 16, 2010 2:55 am
I found a really annoying bug in Loudness. If the Loudness input signal is too loud, it sounds really bad.
If I disable everything and compare these two settings, I would expect roughly the same output:
- Pre Amp at x4.00, Loudness at x1.01 (1.01 to turn it on)
- Pre Amp at x1.00, Loudness at x4.00
However, the first sounds absolutely horrible: Mids push out the bass almost completely, and highs are badly distorted.
So lowering the input level and using a higher Loudness setting to compensate for that currently improves the sound quality. This is clearly a problem in the dynamic behavior of Loudness. Will look into it tomorrow.
PostPosted: Thu Dec 16, 2010 5:34 am
Still same as before, last band EQ still at +2.79 and "DC Remove" is still ON.
PostPosted: Thu Dec 16, 2010 8:27 am
Oops! I uploaded the wrong version :roll:
Correct version is available now.
As I expected, the Loudness input level issue is caused by Punch. Will check it asap.
PostPosted: Thu Dec 16, 2010 1:43 pm
Hans , the link VST version: http://www.stereotool.com/download/vst_ ... 10-80A.dll doesn't run :(
PostPosted: Thu Dec 16, 2010 3:17 pm
In "Loudness and limiting " :
It`s better new options like "De-Essrer" and all "Advanced Bass Distortion Protection" to have ability to switch ON and OFF with check box .
And since these option appear in stereotool ... sound is not that good in high`s and bass . My opinion is to copy the "loudness and limiting " panel from beta 25 and put it to beta 80A .
Then ST is ready to release .... i don`t know 5.10 maybe ?
Hans , Problem is really solved i check it this afternoon . Filter is OK now.
