Post new topic  Reply to topic  [ 239 posts ]  Go to page Previous 18 9 10 11 1224 Next
 Post subject: Re: StudioOne HD / FM
PostPosted: Sun Apr 11, 2021 2:05 am
Fully reworked multiband bands, everything is just better. Still tuning small stuff. Update soon..
Nice!!!
https://fmfeeling.com
PostPosted: Mon Apr 12, 2021 5:26 pm
I was asked to make Plutonium-like preset, usually i don't do those things, but apparently i could edit my StudioOne in 20 minutes.. it's even sligtly less pumpz.
StudioOne_PlutoniumX-HD.sts [375.95 KiB]
Downloaded 460 times
here it is before i delete it from my PC. :D
PostPosted: Tue Apr 13, 2021 2:31 am
Awesome! Thanks as always!
PostPosted: Tue Apr 13, 2021 2:45 am
I need someone to tell me, is it close? :)
PostPosted: Tue Apr 13, 2021 7:00 am
I don't think so... Listen this is BBP Plutonium: http://turadioenvivo.com:8580/stream
PostPosted: Tue Apr 13, 2021 3:48 pm
I have latest BAO and does not sound same as that stream. Maybe they have some mods.
PostPosted: Tue Apr 13, 2021 4:15 pm
Is old BBP... Not the last BAO
PostPosted: Tue Apr 13, 2021 5:21 pm
Sorry, I've mainly listened to BAO in Rustonium. But I do like the sound you have here!
PostPosted: Wed Apr 14, 2021 8:06 pm
The latest official BAO, being only 5-bands, contains a 5-band version with a different description from the Omnia 9 preset, which is 7-bands. I have some Omnia 9 presets I extracted from a 2019 patch on my google drive. Here's the link to the preset you can maybe extrapolate some insight from.
Plutonium v3 for Omnia9: https://drive.google.com/file/d/1UiYYPL ... sp=sharing
Warning about using Omnia9 presets in BreakawayOne: they won't sound like they're supposed to because the settings won't map 1:1, according to Jesse Graffam.
BAO description: Break out the nukes! This one burns a bright, glowing hole in the dial, with *some* mind paid to TSL. Deep, crisp and loud, this is a great preset for major markets.
Omnia9 description: “Plutonium,” the loudest factory preset and the most aggressive of the “atomic” presets, was initially designed to satisfy the specifc needs of a large European broadcast group who not only wanted large quantities of bass, but plenty of bass punch and minimal distortion as well. When processing for all-out loudness, there’s little (or no) room left for bass. Heavy bass clipping makes some room, but at the expense of punch. “Plutonium FM” solves this dilemma by employing the WB AGC2 compressor in the “Bass Only” mode and incorporating the Transient Enhance feature. If your needs call for lots of bass and dial domination, “Plutonium” delivers.
PostPosted: Thu Apr 15, 2021 12:34 am
Yea, i compared with what i have. Waiting Leif to send me O.9 anytime soon :D
