Hey hans, great update!
I found one slight problem:
In the latest posted version (510-72), when I calibrate the 20 Hz frequency signal strength in the FM Calibration window, and I set it to 0, it still produces sound, and even causes the stereo/tuned indicators to flicker on my fm receiver. I'm not sure about previous versions, since I didn't calibrate in a while.
I compared it against version 4.22 - no difference.
There are some filtering issues at very low frequencies (like 20 Hz); if the difference between the 20 and 40 Hz slider gets smaller those issues get less prominent (and if they are equal they are gone).
Note that you should NEVER set these sliders at 0, because normal sound may get pushed outside the valid area (-75 kHz .. +75 kHz on the transmitter), and hence cause dropouts (and worse: Disturbances on stations on neighboring frequencies!).
Do not use this filter to filter out lows or anything! Only compensate for sound card/cable/transmitter offsets!
