Post new topic  Reply to topic  [ 112 posts ]  Go to page Previous 16 7 8 9 1012 Next
PostPosted: Mon Dec 02, 2024 4:57 am
Yes VST2x64 is fine.
PluginDoctor: it's useful, but can be a pandora's box!
Oh, just realized 1041 VST3x64 is not passing signal at all in any host, though it scans ok. Is general advice here to stay a few feet back from the bleeding edge? (new-ish user),
On the contrary, I like to stay updated with betas so I can test all the new features in between releases. I try to forward most issues I can't handle to the team and they get taken care of relatively quickly. Unicode was recently added, and I'm assuming the inability to be seen bug is part of that. I bet it'll return to functionality in this coming week.
However if you run an on air station, it's recommended to stick with stable releases, unless a specific bug is fixed in a beta that you need.
PostPosted: Tue Dec 03, 2024 11:14 am
VST3 should work again in BETA040.
PostPosted: Fri Dec 06, 2024 7:06 am
Thanks.. can report working in Reaper and Sequoia. Still no i/o in Plugin Doctor which weird, I have to check again.
PostPosted: Sat Dec 07, 2024 9:19 pm
Posted BETA044. Now has the ability to create 8 streams instead of 1.
PostPosted: Fri Dec 13, 2024 10:06 am
Posted BETA046. MicroMPX via RIST now works without a static IP address at the decoders! (You still need one on the encoder side, but that's likely much easier to achieve).
How to use:
- Use this new version on BOTH sides. (encoder side can also be Stereo Tool)
- Enable RIST on both sides
- In the RIST mode pull-down menu, choose the 2nd option on both sides
- On the DECODER side, fill in the IP address of the encoder (!)
- On the ENCODER side, enable port forwarding in the router.
The port number must be EVEN. And the port number + 1 is also used, so enable port forwarding for both. If you use 8854, then forward 8854 and 8855.
PostPosted: Mon Dec 16, 2024 12:28 am
I assume you don't release regular version til end of year? :/
Not asking for a friend :D
PostPosted: Mon Dec 16, 2024 12:44 am
Nah, too many open points that need to be finished. RIST almost works, STXtreme 5 FM instances almost works, STXtreme loopback test almost works, Mac VST3 still has some issues, bunch of things like that. We're using this month to fix a lot of smaller issues like these. But there's only 1 week left so I don't expect to be able to release anything.
PostPosted: Tue Dec 17, 2024 2:49 am
Hi Hans
Is there any chance of adding a tick box option when running Parallel Multiband Compression option that changes the scale of the MB2 to mimic the same values or scales used on MB2?
When I started playing with the feature, I thought I had broken it after using the copy MB1 settings. :D
After a couple of hours away from the PC, I realised that the scales were different and were being true to their values. D'oh!
Anyway, just a thought!
Ross
PostPosted: Tue Dec 17, 2024 9:16 am
Hi Hans
Ross
You mean the display scale? Or parameters?
PostPosted: Tue Dec 17, 2024 10:29 am
The display scale. Mirror the scale from MB1 so it is the same in MB2 when linked.
Ross
