Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 167 68 69 70 7176 Next
PostPosted: Fri Dec 07, 2012 4:51 pm
dBpoweramp is running here now and I found a bug: The parameters were loaded but not activated (before there was no split between parameters and processing code, now there is). When there's a GUI, the updates also do this so this only occurred when no GUI was present. I added some code to immediately activate every parameter that is set externally.
@Valiant: This might or might not explain what you are seeing, anyway here it does remember its settings so I hope all will be ok now.
PostPosted: Fri Dec 07, 2012 5:49 pm
Stand alone: http://www.stereotool.com/download/ster ... 33-060.exe
VST: http://www.stereotool.com/download/vst_ ... 33-060.dll
Done:
- Fix calibration window (missing check boxes, lots of them)
- VST version does not process (output=input) when processing a file - viewtopic.php?f=14&t=4334&start=661
- Check STS file saving - Probably fine
- Memory usage: Try building 2 channel instead of 5.1 channel version.
- Memory usage is increased --> Reduced by 25 MB. More (upto another 25 MB) is possible but risky (threading issues), will not do that now.
- FM output sound card still used in bypass mode, plays at far too high speed. Should be turned off.
- New RDS display layout?
- Make sure that RDS lines are not placed on top of each other; make height constant.
- ASIO buffer display Wait for feedback, might be fixed.
- Icon - and display new version or not registered symbol - http://i.imgur.com/p88AG.png
- CARBON_PLUGIN warning
Less urgent for usability:
- Design (several people are working on something)
For later:
- Add 'purpose based' view on settings (for example all settings that affect bass combined).
- Multi-language support
- Add basic/advanced modes
- Confirm on close (stand alone version)
PostPosted: Fri Dec 07, 2012 5:57 pm
Still very similar memory usage.
Yes, it processing now in dbPoweramp.
PostPosted: Fri Dec 07, 2012 8:55 pm
WOW, beta 60 looks good ( bold fonts + red indicator fixed + perfect sound )
I think it`s a kind of release candidate ( exclude if things can be done in GUI view... )
PostPosted: Fri Dec 07, 2012 9:58 pm
:D :D :D Yes, it works now! :D :D :D
And the new v060 standalone gets rid of the white blanket cover over the ST window that I was getting after coming back from minimize. :lol:
PostPosted: Fri Dec 07, 2012 11:06 pm
Also mega fast loading of the settings From load or change them . I saw two times where is the text for non registered things ( text was smashed ) then come back again .
I think text become smashed when click on some settings ( may be with some sequence ) i don`t know.
PostPosted: Sat Dec 08, 2012 2:44 am
Could you add buffer display for asio to the todo list. It's displayed fine in 6.32 but in latest betas it looks like some heart beat.
PostPosted: Sat Dec 08, 2012 3:01 am
Added! (Sorry I forgot to add it earlier)
PostPosted: Sat Dec 08, 2012 12:55 pm
Stand alone: http://www.stereotool.com/download/ster ... 33-061.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 33-061.exe
VST: http://www.stereotool.com/download/vst_ ... 33-061.dll
Command line: http://www.stereotool.com/download/ster ... 33-061.exe
Done:
- Remove compiler warnings
- AXIA input sound card loading issue
- ASIO latency offset missing (was available in 6.32)
- Add ASIO settings button
- Red declipper display broken (caused by memory optimization)
- Add presets
- Change version number
- Add skin by Bojcha in about box
For later:
PostPosted: Sat Dec 08, 2012 1:19 pm
I think Asio display not fixed !
