Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 15 6 7 8 935 Next
PostPosted: Sun Jul 05, 2015 11:06 pm
There is a sample rate bug. The sample rate of the FFT is stuck in 48khz mode. Restarting st fixes the problem but it switches back to 48khz by itself after a while.
Confirmed.
My radio station
http://amradio.ddns.net
PostPosted: Sun Jul 05, 2015 11:12 pm
Confirmed.
I changed something there to improve the display for AM processing, will check what went wrong.
PostPosted: Sun Jul 05, 2015 11:23 pm
Confirmed.
Ok and the cpu change is huge. There is an improvement in the order of 8-10% on my pc. WELL DONE
My radio station
PostPosted: Mon Jul 06, 2015 8:39 pm
Further optimization coming tonight :)
PostPosted: Tue Jul 07, 2015 12:37 am
Stereo Tool 7.71 BETA007
Windows stand alone: http://www.stereotool.com/download/ster ... 71-007.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-007.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 71-007.dll
There are some big changes in the Composite Clipper in this version. The sound should be the same as before (within 0.02 dB or so). CPU load is much lower though. Please be careful with using this version for anything else than testing until proper functioning has been confirmed.
Note: If you want to use the new composite clipper CPU load optimization with Stokkemask, for now you should set the Stokkemask Quality slider to 3 (I still need to fix that).
- Some small optimizations
TODO 7.71:
- Fix optimizations
- Fix code #warnings
- Add downsampling to 38 kHz! -> Should lower TOTAL CPU load by another 10-20% -> Started working on this
- VST multiple instances fails
- Make VST window bigger
- Clipper highs improvement
- Noise learning Micha
- EQ with 'standard' sliders.
TO DO WITH LEIF:
PostPosted: Tue Jul 07, 2015 2:40 am
ı cant download
PostPosted: Tue Jul 07, 2015 3:05 am
Not Found
The requested URL /download/stereo_tool_standalone_installer_BETA771-007.exe was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
PostPosted: Tue Jul 07, 2015 5:05 am
Whoops! I forgot to press ENTER. Uploading now...
PostPosted: Tue Jul 07, 2015 5:13 am
Working. Thanks!
PostPosted: Tue Jul 07, 2015 6:12 am
I see new slider and it's called "true peek". Anyway, right away i saw less cpu usage. from 22-25% to 15-19% (slider at 4), nice. When i wake up in 3-4 hours will chack quality :)
edit:
I also see new slider in "highs gap"
