Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 14 5 6 7 843 Next
PostPosted: Tue Jul 12, 2016 11:30 am
Hey Hans,
8.01 BETA006 Winamp Plugin,
On mode, no audio output, even after a Factory Reset. All visual appears to be OK.
Bypass mode, has unprocessed audio.
Aussie.
PostPosted: Tue Jul 12, 2016 2:08 pm
Beta 006 quick test - loading Aussie Coastal Dreams (and a few others I tested) gave an exception. Restarting seemed to give another.
It seems a bit odd because audio locks up when you get the message but you can get it back by changing the preset to something else. Maybe something preset specific?
Edit: This is on Win 7 32 bit (SA).
Fixed!
PostPosted: Tue Jul 12, 2016 2:09 pm
Hey Hans,
Aussie.
Cause found, the "Send to Winamp" setting is used even if FM is disabled. Fixing it now.
Edit: Fixed.
PostPosted: Tue Jul 12, 2016 2:19 pm
Now it works fine, no crash :)
but post amplifier not works and levels goes very high.
I can't reproduce this here - Post Amp works with all the settings that I've tested so far. I'm probably missing a case (I did rewrite all the Post Amp code so it's very likely that something is broken). Can you send me your settings?
PostPosted: Tue Jul 12, 2016 2:20 pm
Installed 8.01 BETA 006 on my PC. No crashes on startup.
First I had no sound when ST was enabled, only when set in Bypass. I had to set "Send to Winamp" to "De-emphasized version of FM output" before the sound did go through to my speakers.
FM Output is Off.
Fixed!
CPU usage on my system is about 40%, equal on both cores. I have a Intel(R) Celeron(R) CPU G540 @ 2.50GHz on this system, so a rather slow CPU.
Is this different from before? Note: CPU affinity doesn't work yet in the new design, so you could be getting somewhat different spread over cores - the total CPU load should be roughly the same as before though.
PostPosted: Tue Jul 12, 2016 3:16 pm
Here is the STS file. Caught crash error with this.
I did notice that if you preset with Aussie - Alpine Dreams, no crash, but no sound either..
PostPosted: Tue Jul 12, 2016 4:22 pm
Fixed a few more bugs. The new "Threads" slider under CPU & Latency should basically work now! If you have a slow CPU with more than 2 cores, this might help...
Windows stand alone: http://www.stereotool.com/download/ster ... 01-007.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-007.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-007.dll
Known issues:
- Memory leaks on close
PostPosted: Tue Jul 12, 2016 4:53 pm
Hans,
TST8.01BETA007
Single core rotations is working a treat. The resource starving to TST when running with Teamviewer stop and it runs sweetly.
The result photos on CPU talk for themselves.
PostPosted: Tue Jul 12, 2016 4:59 pm
Known issues:
sound 8.01 really MUCH better, threads working nicely on q6600 quad Windows X, couldn't test Linux yet
https://maasstad.online/
PostPosted: Tue Jul 12, 2016 5:11 pm
Wow, go Hans, this is a huge improvement on the lower end CPUs with SingleCoreRotations and Threads. A game changer!
Now successfully have Aussie - Coastal Dreams running at 100% CPU setting, just have to enable Ignore High Freqs.
Everything is running, All Repair items, Stokkemask is running & can even do the RF spec calculations.
