32 bit stand alone:
http://www.stereotool.com/download/ster ... 44-002.exe
List of changes:
THIS VERSION:
- Fixed VLC synchronization behavior (now synchronizes to input, before it turns out it synchronized to an internal VLC timer). This means that synchronization will be much more precise now on short term, and drifting apart which could happen before should also be gone.
- Fixed VLC crash in 32 bit version introduced in previous beta 744-001.
- Loading a preset no longer resets Auto-start with Windows, Detect and attempt to fix sound card/VLC timeouts, Restart on crashes or unsolvable sound card timeouts
OLDER:
- Lost audio when playing with MB flatness levels at maximum steepness, exceptions logged on 64 bit - SOLVED.
- AGC bugs reported by Action (page 2 of this discussion), solution is to change range of parameters. SOLVED.
- Error message must be changed: "I had that restart ST error as well when I had loaded a settings file which had another audio card defined. I just selected the right audio card and it was OK." DONE (not yet in next beta)
- Speedup building by removing stuff from Param.h
- Changed AM presets (now enable "AM" mode, and pre-emphasis for US).
- Juli@ sound card problem nelson c. - BAD TIMER RELATED - FIXED by doubling timeout time.
- AM MPX display does not work - sometimes -> oddly I cannot get it to 'not work' anymore... -> Seems sample rate related. Now hiding the display when sample rate is low.
- Remove exception message when loading a preset with a non-existent language setting (from a different pc). -> Hm, I can't reproduce it anymore...
- 64 bit restarting twice behavior: When I click the “TEST ERROR (CRASH)” button, an ST-dialog box show up, and after clicking OK, Stereo Tool crashes and restarts itself, runs for about 10 seconds, and then it crashes and restarts once again. So far unable to reproduce it, and after restarting twice everything is ok again.
