Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 14 5 6 7 876 Next
PostPosted: Fri Aug 24, 2012 4:58 am
thank you very much for the explanation!. congratulations on your work :!: . from your server immediately charge :)
PostPosted: Fri Aug 24, 2012 5:12 am
New "quick orange" test skin - http://85.25.73.243/stereotool_skin_o1/
PostPosted: Fri Aug 24, 2012 10:30 am
Forbidden
You don't have permission to access /stereotool_skin_o
1/ on this server.
Apache/2.2.3 (CentOS) Server at 85.25.73.243 Port 80
I think something might be wrong there.
PostPosted: Fri Aug 24, 2012 12:04 pm
Directory browsing is disabled but skin should work if you follow the steps.
PostPosted: Fri Aug 24, 2012 1:43 pm
Added tags so I can now group widgets together without having to jump to a new line every time. Also, if the groups fit on a line it will not be split (it will start on a new line if it doesn't fit on the current line anymore). Interface now automatically adjust to window size, buttons are constant-size now.
Same filter in a smaller window:
(Not using Bojcha's skins for these screenshots because they are not yet adjusted for this new layout).
PostPosted: Fri Aug 24, 2012 4:39 pm
Very nice to watch this come to fruition. Great clever new look!
PostPosted: Fri Aug 24, 2012 5:37 pm
I'm not sure if this is an improvement or not: Sections are now closed by default and can be opened.
Note: New GUI items are REALLY ugly, I didn't have time to make anything decent. I just want to check & get feedback on the behavior here...
http://www.stereotool.com/download/ster ... 33-009.exe
Tested in FF and Chrome, broken in IE.
PostPosted: Fri Aug 24, 2012 5:59 pm
I think it makes more sence if only complete parts can be hidden. Like "Global Settings", "Sound Cards" etc. And just let all sections be visible.
PostPosted: Fri Aug 24, 2012 6:09 pm
Double tilt correction in the web ?
report this to see what is goin there.
And when i set option one time then it`s not displayed in the GUI again ( enable/disable any option ) in my case this was the tilt correction and then no "checkbox" appears in the GUI after first time check/uncheck in WEB
...like not working anymore.. where is the answer ?
PostPosted: Fri Aug 24, 2012 7:02 pm
That will come anyway (you will be able to select one filter at a time). Still, in some cases the number of buttons and sliders is huge, esp. If you're working on a small display (mobile phone, touch screen).
