7.85 BETA073
Windows stand alone:
http://www.stereotool.com/download/ster ... 85-073.exe
Winamp DSP:
http://www.stereotool.com/download/dsp_ ... 85-073.exe
Windows VST 32 bit:
http://www.stereotool.com/download/vst_ ... 85-073.dll
CHANGED:
- License key bug (Camclone) fixed.
- Asymmetry follows normal FM LPF frequency
- Reported that Nicholay Vachev's presets sound bad (distorted) in BETA063. --> Woops, in older versions BS412 was active even if FM wasn't enabled! And this preset had BS412 on.
- Add "Rules are there to be broken" block?
- Add Quadrature limiter/clipper
- Try allowing even more Quadrature noise, or faster via mirrorring. Try optimizing without x4.
- Optimize Quadrature clipper
- Fixed bug in string parameter class that could cause weird behavior (including a heap check fail in debug mode, sometimes), which was introduced in an earlier beta.
- Try Quadrature for BS412 -> No
- Try allowing more Quadrature noise -> Yes, now at 0.1-0.4 dB extra (was 0.1-0.2).
- Crash during startup in BETA069 fixed.
- Option added to allow Quadrature noise, this allows about 0.1-0.2 dB extra loudness (and a more open and less distorted sound) through the clipper. Might have some negative effects on stereo separation though on certain radio's (although it shouldn't be worse than some other processors' default behavior).
- Fixed logged out mode (needs to be updated for newly added pages and settings)
- Finalized RDS HTTP commands (Arctic Palm) - wait for test results.
- Crashes sometimes (since 061). -> Appears to be solved.
- Fixed 16/24 bit LSB ASIO format for new AudioScience 192 kHz capable sound card. - Matt Levin will test
- Add RDS HTTP commands (Nashville - talk to Arctic Palm) - Partially done - Arctic Palm will test
- Crash in Delossifier
- HD: Label "Diversity Delay" & add "HD" label to streaming
- Bass AGC (Old) is broken! -> Oops, new Ratio was implemented but it had a 1000:1 ratio instead of 1:1000!
- OPTIMIZE DELOSSIFIER
- Reduced stack usage, hopefully fixes crash issue
- Fix AGC ratio display
- Absolute Highs: Optimize performance: Check log() -> Removed most (256 to 40 per step), and part of code that's not needed disabled for Delossifier.
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be.
- Fixed GUI bug. Maybe that fixes the gray screen that was reported by RadioImInternet - but I'm not too sure about that.
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Absolute Highs before Noise Gate
- Check NAN's reported by baires
- Check memory leaks in stand alone version -> Caused by ASIO load bug, extra check added to avoid it in most cases.
- Compiler!! See VlcInfoFunctions.ci for example how to use external DLL.
- Add uMPX license keys
- Fix uMPX debug mode
- Check uMPX memory leaks
- Add uMPX non-licensed behavior
- Pul Paul's preset in!
- Call GuiToCommand in Generic plugin
- Make Absolute Highs 1-band mode respond to set frequencies.
- Bug in Absolute Highs; Vibrating sound -> Not there anymore?
- uMPX crash on repeated closing.
- Check & handle emails
- Reply to "Ask"
- Latency 9sg checken
- Koek - 5 pagina's
- Delossifier: Check why 16 bit MP3 at LekWaalFM doesn't get improved more by Delossifier (might be a hardcoded maximum somewhere). -> No, signal doesn't go down as steeply. Might be ok?? --> Alternative Reconstruction seems better in this case, but sometimes causes weird (LOUD) artifacts. Fix that. Also possible that we just need more Effect Strength setting due to the shallow drop (why is that anyway?).
- Delossifier: Make slower drop. Current drop speed still causes annoying effects.
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- Fix weird startup bug -> Not seen anymore. When this happens, the pilot/rds are "broken" (signal jumps). Reloading the preset fixed it. No idea why... Only seen in .ST version.
- Use 4 (or 8) cores for processing, Raspberry Pi etc. Or Clipper on separate CPU?
- LW buffer bug - if the Normal Output buffer is large, LW input hangs. But not always... - Unable to reproduce so far... (Logging added!)
- Absolute Highs has pre-ringing/mpeg like artifacts, try smaller block size (I think I increased it at some point to better filter annoying tones but that caused this problem).
- OS X update wxWidgets for 10.10.5 compatibility -> Mathijs
- License check
- Stand alone program & VST with demo option to do Declipper, Delossifier, AZIMUTH, Dequantizer, PNR, Natural Dynamics. (No noise gate!). Somewhere in next 2-3 weeks. ProTools plugin without demo. Maybe run limited time and stop. Or announcement every 25 seconds.
- O skin
- Brief Polen
LATER:
- Try Delossifier on L-R??
- Delossifier: Pre ringing killer causes volume bumps. Which seems to sound good!!! Add a feature for this?
- Normal Output: Don't output FM anymore! Use plugin_or_fm_output_enabled && !ALWAYS_SOUNDCARD_ACCESS. But that's not all - also check different lowpass freqs and clipping levels etc. Might be better to combine this with sound card redesign.
- set Encryption : impossible to view or modify all the processing settings. Solution is: Password like there is now (but only on Processing/repair settings!) to unlock viewing the settings plus one to load the .sts file (in the .ini it should load automatically I think...). In both cases, we could point to a separate fle that contains all the encoded settings. In case of .ini the password for unlocking must be stored in the .ini file..
- Preset Licensing : encrypted preset without beeps unlocked by a license - or never visible?
- Add filter to optimized processed audio for lossy codecs? See comments (//#warning) in Clip1Ch::clean1ch()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly? (Maybe already ok?)
- Show band frequencies in GUI (Natural Dynamics, MB).
- Try: Volume difference effect with different speed at different frequencies (From Pre-ringing killer)
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Add HTTP commands and feedback -
viewtopic.php?f=16&t=7701&p=34436#p34436
- Add sound card adjustment presets for analog sound cards.
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
LATER 2:
- Auto-detect wrong sample rate conversions.
- Clipper: Try pre-filling quadrature! Put in pilot_rds signal. What about BS412?
- Add RT+ and Arctic Palm-like formats to help page
- Add auto detection of certain sound cards, like Marian Trace Alpha.
- Check Sort algorithm optimization
- MB: Add voice volume protection, don't allow mid bands to drop below surrounding (to some extent), protectes voices and it might help to replicate the sound of certain other processors
- Make DIFFERENCE work in Natural Dynamics for separate bands
