Post new topic  Reply to topic  [ 166 posts ]  Go to page Previous 13 4 5 6 717 Next
PostPosted: Thu Mar 21, 2019 6:12 pm
Version 011 is uploaded (stand alone only). Now with built-in streaming support (for now: IceCast, MP3 via LAME, ogg/Vorbis).
it all looks very promising! could you please add the opus codec? I think you should definitely support it, because the 1st is Open Source, and secondly the quality is outstanding.
PostPosted: Thu Mar 21, 2019 6:51 pm
+1
PostPosted: Thu Mar 21, 2019 7:23 pm
Shouldn't be hard to do... Does anyone stream in Opus though?
Edit: Ow. Might be harder than I thought. The library that we're using doesn't appear to support it.
PostPosted: Thu Mar 21, 2019 8:22 pm
AAC should come first, and derivates
PostPosted: Thu Mar 21, 2019 8:40 pm
Red color input levels. It looks like you use input gain but I don't used It. Beta 9.24-012 Stand alone 64.
Edit: I use the breakaway pipeline from breakaway one. Before I don't have this problem latest beta I test was 9.24-009
PostPosted: Thu Mar 21, 2019 9:06 pm
beta12
Built-in streaming output messes up buffer on normal output. Ofc sync does not help, it does not even work.
Some internal separation between this two need to be in place. It should not happen nothing on normal output when you type streaming password or just turn on and off streaming.. etc.
Post-Amp should not be included on streaming, especially when there is a separate one for that.
PostPosted: Fri Mar 22, 2019 12:50 am
The Stream Engine will need to support upto 4 streaming servers, for redundancy/loadsharing purposes.
PostPosted: Fri Mar 22, 2019 4:38 am
Agree! :mrgreen:
PostPosted: Fri Mar 22, 2019 10:29 am
beta12
Seeing this too (Win10P, 64Bit SA), with no Streaming Output enabled seems to still cause issues.
It also seems to have a knock-on effect with FM Output - NOut goes buffer overrun, resets and then FM Out starts and eventually does the same. NO is running Separately Processed Steaming / HD. Have doubled the buffer/diversity delay for both from my normal settings to calm it down but it still gets caught up...
Occurring in Beta 11 also.
Ross
PostPosted: Fri Mar 22, 2019 10:33 am
beta12
Agree, and we have people working on that - so I'm not going to fix that now anymore, there will be a new I/O layer soon. Which will also solve other issues, and add more flexibility.
Then what is it for? All output already have a level slider (except in the plugin versions). So, you're basically saying that Port Amp should be removed I think?
