Post new topic  Reply to topic  [ 143 posts ]  Go to page Previous 13 4 5 6 715 Next
PostPosted: Tue Nov 27, 2018 2:27 pm
yeeey another one.. bass.
PostPosted: Tue Nov 27, 2018 5:03 pm
Reminds me of that Meghan Trainor track: It's all about that bass, no treble.
When can we expect that matrix stereo widener?
PostPosted: Tue Nov 27, 2018 6:28 pm
Somthing went wrong whith latest beta... ;)
Added new bass filter (not yet finished)
PostPosted: Fri Nov 30, 2018 1:55 am
Stereo Tool 9.12 BETA011
Windows stand alone: https://www.stereotool.com/download/ste ... 12-011.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 12-011.exe
VST 2: http://www.stereotool.com/download/vst_ ... 12-011.dll
VST 3: http://www.stereotool.com/download/vst_ ... 2-011.vst3 DOES NOT YET WORK IN ALL PROGRAMS (vMIX for example)
Windows stand alone: -----://www.stereotool.com/download/stereo_tool ... 12-011.exe BUILD FAILED
VST 2: https://www.stereotool.com/download/vst ... 12-011.dll
VST 3: https://www.stereotool.com/download/vst ... 2-011.vst3 DOES NOT YET WORK IN ALL PROGRAMS (vMIX for example)
  • Finish Immersive Bass: Add better HPF, tilt, non-lossy adder, update name to Immersive Bass, updated presets.
  • RDS: Remove dynamic memory allocations when the PS/RT/PTYN strings are modified. Pre-allocate enough memory once.
  • RDS UECP: Add support for multiple UECP encoders with different port addresses.
  • RDS UECP: Add support for multiple site/encoder addresses.
  • Add Mathijs' new preset
    I know, yet another bass filter. Mathijs was complaining that the bass still didn't sound right. It lacked warmth. We started experimenting, and at some point his reponse was "That's it!". So, we've worked on adding that specific bass. Somehow, I've never missed it, but when I listened to it in my car, I suddenly had the feeling that I was "bathing in bass". Hence the name "Immersive Bass". Interestingly, it is less noticable on my monitor speakers in our office.
    Earlier filters such as Basstardiser now sound "hollow" in comparison, and I would describe this new bass as "warm". The new "Dutch Chocolate Moose" preset is using it. Still work in progress, but it's close to Dutch Moose, with more of "that" bass.
  • VST3 plugin doesn't work in vMIX - fixed something...
  • Added new bass filter (not yet finished)
  • VST3 64 bit plugin fixed (32 is probably still broken)
  • RDS: UECP: Site and Encoder address were swapped. Fixed, not tested.
  • CPU load 100% in web thread Linux?
  • No ASIO asserts in debug mode
  • Group 15B also send 4x on TA start (was only doing it on end).
  • Added odd/even harmonics selection in Basstardizer (was only odd before).
  • Nicer input sound card open error handling (softer beeps, retrying and restarting added).
  • RDS: Add PIN to interface
  • VST3 plugin
  • Volume display FM output seems wrong when streaming output is enabled with separate processing. Almost certainly only GUI issue.
  • Noise gate windows audible
  • Auto-select 192 kHz FM output sound card as default
  • No PIN EWS
  • Look at text alignment
  • Split RDS features in standard and advanced RDS (EON, AF method B, ECC, EWS, ODA - TMC etc)
  • RDS AF method B
  • RDS AF method B via UECP Probably done but can't test it now.
  • White screen in generic plugin - was caused by wrong #ifdef
  • I/O and BIMP missing in web interface.
  • What does the new Immersive Bass display show? Either remove it, or add it to bottom display as well.
  • Immersive bass: Added protection to not add it if it's already there (can be defeated, for now, for testing).
  • Check new installer script
  • Is VST3 ok in vMIX after the latest build?
  • MicroMPX: Add manual (how to setup)
  • Glitch when turning Bypass off
  • Linux MicroMPX version
  • 1024x600 screen misses VU meters
  • AAX plugin
  • Right-click tray icon bypass is bad
  • Dutch Moose schelle vrouwenstemmen
  • Linux-version MicroMPX integration in ST.
  • Support for more than 32 ASIO channels
  • Automate generating MicroMPX licenses
  • Automate generating The BIMP licenses
  • Backup audio doesn't go to LQLL
  • Finish Kantar tests and integration
  • Brian, NAB
  • VST for DJB
  • Test sound card
  • Linux multiple instances
  • Fake stereo idea
  • Cntrct IN
  • Add a popup for buffer overrun/underrun (also for suspicion)
  • Test ProppFrexx Windows 2012 server issue-
  • RDS: RT end at \n
  • Noise in declipper issue
PostPosted: Fri Nov 30, 2018 1:56 am
Well with that changelog, it's time to ditch stable and jump back on the testing bandwagon!!
PostPosted: Fri Nov 30, 2018 9:21 am
9.12 BETA011 64bit shows 010 and is not updated.
PostPosted: Fri Nov 30, 2018 9:56 am
Ah, I see. The build must have failed. Please use the 32 bit version for now then.
--> I see now. The stand alone build failed due to an out of memory error (my build pc has 32 GB, that doesn't appear to be enough anymore...). I thought it was a 32 bit error and restarted that build, but it probably was a 64 bit build error.
PostPosted: Fri Nov 30, 2018 4:47 pm
The latest beta of the VST3-64 version is unfortunately not (anymore) recognized in Audition. Once it was recognized and I could play with it. At that time there were problems with the display, as I wrote in my last post. Also, part of the Auditon interface was overwritten by the StereoTool. So you couldn't even apply the effect because the "Apply" button wasn't visible at all. And if you used the dynamic plugin scaling, then the area of the application that was overwritten by the StereoTool flickered.
PostPosted: Fri Nov 30, 2018 6:56 pm
Nothing was changed in the VST3 interface compared to beta010. Was your previous version 009?
PostPosted: Fri Nov 30, 2018 7:17 pm
No, my last beta was 007. Unfortunately I could not test the versions in between (due to time reasons). Now I wanted to look at the newest one again, and notice that it can be loaded, but does not appear on the surface. If I do the same with the 007, then I see an entry here at least... :roll:
There must therefore be some difference between the two versions if I can open one and it is displayed to me and the other does not appear.
