Post new topic  Reply to topic  [ 445 posts ]  Go to page Previous 135 36 37 38 3945 Next
 Post subject: Re: Preview...
PostPosted: Fri Jun 12, 2009 11:56 am
Does that mean I should update your preset?
For impact no (shuld be renamed to Radium)
For Balkan yes .. from 2.52 to to 2.67x.
PostPosted: Fri Jun 12, 2009 6:44 pm
Hans,
I also made a couple of changes to my deep low preset, can i e-mail you the new one so you can set it up in the new version?
/Martijn
PostPosted: Fri Jun 12, 2009 7:11 pm
Hans,
/Martijn
Sure, but please be fast - I'm about to release it. stereotool@hansvanzutphen.com .
PostPosted: Fri Jun 12, 2009 7:55 pm
it's now in your mailbox.
/Martijn
PostPosted: Fri Jun 12, 2009 10:03 pm
/Martijn
Wooh! Isn't the first band a bit too loud (+18 dB!)? I'm hearing a bit of distortion again... (Not much though). But the highs are about 0.5 dB lower than before... (Bass is +2.2 dB).
PostPosted: Fri Jun 12, 2009 11:29 pm
There is one big problem!!
Who's gonna write changelog :D
that is going to be looong list :)
Wooh - that DID take a lot more time than I had expected...
http://www.stereotool.com/version_history.shtml
PostPosted: Fri Jun 12, 2009 11:38 pm
hehe
PostPosted: Fri Jun 12, 2009 11:40 pm
I still have to update the images on the site but...
http://www.stereotool.com/download/
PostPosted: Sat Jun 13, 2009 12:14 am
JabbaDabbaDabbaDooooooo !
Ladies and Gentlemen,
the final Beta had a size of 704 KB (721.539 bytes) !
(I hope this time it is the correct version)
No more flickering.
The audio quality cannot be described with words.
And where others have only more or less ridiculous presets,
Stereo Tool gives full access to tweak every detail.
Hans, there is only on last serious graphics problem:
You should spend more bytes for your photo.
If 700 or 1000 KBytes, who cares ?
PostPosted: Sat Jun 13, 2009 12:18 am
and install file ?
